Question about NetGear WGR614 Router
How do I make this a secure connection? I'm having problems with everytime I open a webpage I receive an error message that says try again...after several refresh tries I will receive access to the webpage. Help please, why is this happening? Is it because me connection is not secure or why?
  • NetGear Master
  • 2,219 Answers
No, you have a bad internet connection.
Sort that out first, try not to use wireless connection until you have established a good fixed cable connection.
Then test out the wireless connection.
Posted on Mar 08, 2015
5 Suggested Answers
serra_baby
  • 144 Answers
SOURCE: NETGEAR WGT624 Router Troubleshooting
Hello!
Inability to access certain websites is due to three main factors.
  1. Security on the web browser is set too high
  2. MTU not set on the router properly
  3. Secured websites
Lowering Down the Security Settings on Internet Explorer
Step 1: Double-click Internet Explorer and click Tools.
Step 2: Select Internet Options, click Security then Custom Level. A window similar to Step 3 will appear.
Step 3: Select Medium-low under the Reset to drop-down menu.
If this did not work, you may try to:
-- enable the MTU on the router.
-- forward port 443 on the router
Posted on May 06, 2008
watz up
  • 6 Answers
SOURCE: netgear dg834gt problem connecting to hp pavilion dv4000
HI
NOTE: The following setup info .is for da PPPoA connection type.(most common in UK).
Its advised to keep da ethernet connected to your laptop untill you configure da wireless on the router, you can disconnect da ethernet cable after the confoguration is over to connect wirelessly.
Try the following: check if your PC is communicating correctly with router. (You might need to restart the computer, after the router is connected to it). On the desktop click on Start and then on Run. In the open box, type cmd.
It will bring up the command prompt window
Type command ipconfig in that window and press the Enter / Return key on the keyboard. It will bring up results similar to the image below.
Note the values of IP Address and Default Gateway in the ipconfig command results. If the IP address is in the range of 169. 254.x.x or 0.0.0.0, then your PC is not communicating to the router. In such a case contact your router vendor for support.
If the IP Address is in the range of 192.168.x.x then the network setup should be ok. Note down the values of IP Address and Default Gateway. Close the command prompt window.
Open Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of a Netgear router it should be 192.168.0.1
It should bring up the logon window similar to the image below. Type the router username and password in the respective text boxes. Refer your product manual for the default Router username and password. In case of most Netgear routers, default username is admin and password is password. Then click on the Login button to continue.
In the next window that appears, click on the setup wizard button
This should bring up the Setup Wizard page similar to the image below. Select Country as UK and Language as English. Under Auto-Detect Connection Type, select No. Then click on Next button.
Basic Settings page will appear. Under Does Your Internet Connection Require A Login?, select Yes.
Configure the following settings in the window:
  • Encapsulation: Set it to PPPoA (PPP over ATM)
  • Login: Type your login name. (in most cases its the primary email address that you get from your ISP)
  • Password: Type you account password. (make sure there are no spelling or case mistakes)
  • Service Name: Leave blank.
  • Idle Timeout: Set to 0.
  • NAT: Select Enable.
Now click on the Apply button. (Please note that it may take up to 5 minutes to apply the new settings)
Then ckick on da wireless settings option.( its on the left pane on the window).
- keep the channel as 11.
- mode can be g&b
Make sure that da option WIRELESS ACCESS POINT is enabaled.
Also check da security options .... I would suggest use WPA-PSK encryption.
make a note of da shared key(network password).
ckick apply and wait till it saves the settings.
Disconnect the ethernet and try connecting to the wireless network with the correct security key.
Hope this helps you.
cheers
SHADAB
Posted on Sep 13, 2008
anandg27
  • 1272 Answers
SOURCE: Having major difficulty in connecting to the
Hi, Follow the steps below to configure settings:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the User Name as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Scan for the wireless network on the wireless enabled computers and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 13, 2009
LearnerSA
  • 79 Answers
SOURCE: hello expert, untill a view days ago everithing
Please follow the link its very helpful to you
link
Posted on Sep 17, 2010
Android phone
Do you have your contacts backed up?
Try uninstalling Facebook if that is installed. If this does not fix your problem then try the following.
Settings>Applications>System Applications>Contacts Sync Adapter and press Clear Data, this error usually goes away. If this doesn't work, try clearing the data on Settings>Applications>System Applications>Contacts or Settings>Applications>System Applications>Contacts Storage.
Jun 26, 2013 | Cell Phones
Cannot access a site although have put in browser, to acitvate it, have been having error page 403, gone into browser but still will not allow access to stite requested.
HTTP Error 403 is an error message which means that you are not authorized to view the web page which you are attempting to load. Usually, the HTTP error 403 - Forbidden means that access to the file/folder you are trying to open has been denied, either on intention or owing to a configuration anomaly. You could attempt using a proxy website if the access is blocked intentionally.
May 29, 2010 | Microsoft Internet Explorer 8
Di-624 ''blocks'' me from accessing email account
same as my router just reset the router but make sure you have password on your router
Oct 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
New message folder error
delete all existing messages in ur phone,this is the solution for ur problem...try this
Oct 01, 2009 | Sony Ericsson W350i Cell Phone
Hi, I keep getting this everytime I try to pay for something online by card. ''Navigation To Webpage Was Cancelled'' Any Ideas?
From Microsoft: "you may experience a problem when you visit some Web pages that are in different Internet Explorer security zones. When the problem occurs, you receive a message that resembles the following: Navigation to the webpage was canceled
This problem occurs if the navigation causes Protected Mode settings to change from On to Off. You can determine which Internet Explorer security zone a Web page is in by looking at the status bar at the bottom of the Internet Explorer 7 window.
This problem occurs because Internet Explorer 7 switches Protected Mode settings when certain Web pages are configured in the Trusted Sites area of the Security tab of the Internet Options dialog box. By default, Protected Mode is set to Off for Web sites that are configured in the Trusted Sites area"
Go here for the fix:
http://support.microsoft.com/default.aspx/kb/967941
Jun 20, 2009 | Computers & Internet
QB Pro 09 navigation to webpage window pops constantly
This message occurs because, even if you are not on the internet, many of the internal pages in Qb use Internet Explorer.
Look Here:
https://support.quickbooks.intuit.com/support/articles/sln43713
Jun 17, 2009 | Intuit QuickBooks Premier 2009 Full...
ACCESSING YAHOO
yahoo are experiencing lots of problems at the moment, when I send emails to yahoo adresses I get them sent back almost immediatley.
Nov 26, 2008 | Yahoo Mail
Webpage Browser Connection
Hi. Try Tools, Internet Options, Reset. Also might be worth having a quick look in c:\Windows\System32\Drivers\etc at the Hosts file. Open it with Notepad and make sure you havent got a load of webpages in there being blocked.
Try those.
Darren
Jul 05, 2008 | Microsoft Windows XP Professional
Explorer- IE Cannot load Webpages
What are you using for connection? WIreless, Lan? Go to start, run, and type in cmd push enter. then type ipconfig, press enter. This should bring all of your network connections. If you are going through a router(Wether it be Belkin, linkysys, or some other brand), the default gateway is where your connection is going through. try to ping your default gateway first. You should get four responses. If you don't there is a connection issue. I have a few other suggestions, but try these first. I hope they help.
Apr 13, 2008 | Microsoft Windows XP Home Edition
NetGear WGR614 Router Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
