Question about Hotpoint HSM25GFRSA
The water stopped flowing from the despenser. So I replaced the water copper line and also the filter. The ice maker is fine! No water. Can you help me?
  • John Marsh Jan 05, 2011
    You're very knowledgable!
  • John Marsh Jan 16, 2012
    I fixed it myself! Poured a little water in door area and also in the back area of ice box! Then hold the selector for 60 seconds periodically to push water through copper line from supply line underneath home. You can also turn your degrees down in the winter to conserve energy!
  • 1,772 Answers
Gfd
dfg
Hello and sorry to hear about your problem.
90% of the time you will have 2 issues, the water lever switch has failed or the main water inlet valve has failed.
I have tried to help you. So please help me and Vote/Rate this response. Thanks and good luck.
If you live in the Denver Area, I can help you.
Posted on Jan 01, 2011
Testimonial: "COOL!"
I have the same unit with the same problem. Ihave narrowed it down to a problem within the door. Just below the freezer door lower hinge is a water line connection. I have water up to that point. I have tried to blow compressed air through the water line in the door suspecting a clog but can't get anything through the dispenser even while holding the lever down. I'm trying to find out if there is some kind of a check valve or orifice or something like that in-line inside the door and what might be the least evasive way to get to it.
Posted on Jan 16, 2012
  • Ronnie Vanvarden Sep 18, 2013
    I have the same issue. After working with it for a while, i got the blockage free using a long weedeater string from both sides. The water has frozen in the line blocking the dispenser from working. Yet the next day my line was frozen again. Next step for me is contacting the company because this is a major design flaw.
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Dec 08, 2010 | Whirlpool Refrigerators
Water flow to ice maker has been reduced to
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | General Electric GSS22JET Side by Side...
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Automatic ice maker won't make ice
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Aug 02, 2009 | Kenmore Refrigerators
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Hotpoint HSM25GFRSA Logo
351 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
