Ferrari Remote Control  Enzo Fxx Car Rc Cars 1:10 Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No range on remote to car - Ferrari Remote Control Enzo Fxx Car Rc Cars 1:10
Anonymous
Level 2:
Sergeant:
  • Expert 298 Answers
  • Posted on Jan 01, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
298
Questions
0
Helped
62735
Points
924
This depends on what exactly the problem is, if it used to have a long range, then you should replace the batteries, the range reduces as the batteries weaken.
Remote will only start when i am close to vehicle
It depends on many things - mostly the range of the system itself and especially where you located the remote antenna. Some installers don't use the antenna and that will limit range severely. Most manufacturers want the antenna routed up the windshield pillar and mounted near the top of the windshield glass. This gives best reception since glass does not hinder the RF signal. OF course, a weak battery in the remote can cause range issues as well.
Remote control has very short range
1. make sure battery is inserted correctly.
2. Do you have 2 remotes? Are they both exhibiting short range? Maybe bad remote if 1 is OK and the other is not.
3. Try this to extend range: hold remote under your chin and touching your chin while pressing the button. Your head acts as an antenna to extend the range.
RS 915 says ot of range
the antenna could be loose either on the transmitter from your vehicle or the antenna on your remote.
Remotestarter
Maybe the battery in remote is low or the remote itself may be limited in range. I installed an alarm system to an older truck.
It came with 2 remotes and one of them had a range of 10 feet
even with a new battery.
1helpful
How can i get my key remote to lock my car it has a new battery plz reply asap. just need to know how to reset it
TECHNICAL SERVICE BULLETIN
Bulletin Nbr. 831-2429
Date: January 2004
Market: all
Remote control does not work
Cars affected
- 9-3 (9440) 4D M03-M04 within Vehicle Identification Number range 31045482 - 41021353
- 9-3 (9440) CV M04 with column integration module (CIM) 433.92 MHz, within Vehicle Identification Number range 46000001 - 46006859
- 9-3 (9440) CV M04 with ESP and column integration module (CIM) 433.92 MHz, within Vehicle Identification Number range 46000001 - 46006710
- 9-3 (9440) CV M04 with column integration module (CIM) 315 MHz, within Vehicle Identification Number range 46000001 - 46009855
- 9-3 (9440) CV M04 with ESP and column integration module (CIM) 315 MHz1 within Vehicle Identification Number range 46000001 - 46009843
Background
Under certain circumstances the remote control receiver, which is located in the CIM, may cease to function. The software in the column integration module (CIM) must be updated so that the remote control operation achieves full functionality.
In the case of customer complaint the following procedures must be carried out.
Symptom description
The car cannot be locked or unlocked using the remote control.
Procedure
Before any action is taken, check if the deficient functionality of the remote control receiver is due to incorrect software:
^ Check if the fault is due to the loss of synchronisation between the remote control and the car.
- Insert the key into the ignition for at least 2 seconds.
- Does the remote control work?
YES: Updating the software, in accordance with this TSB, does not rectify the fault.
NO: Continue to check as follows
^ Remove fuse F2 from the dashboard electrical centre. Wait for at least 5 seconds.
^ Fit fuse F2.
^ Does the remote control work?
NO: Updating the software, in accordance with this TSB, does not rectify the fault.
YES: Update the software in the CIM.
1helpful
Poor remote control range
have you changed the battery inside the remote yet?
Increase range for remote starter on 2007 grand prix
Try changing the battery in the key fog. If that doesn't work you can try finding an aftermarket key fog with a greater range. It is probably just default range.
Top Ferrari Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Ferrari Toy Expert? Answer questions, earn points and help others
