Question about Gateway FPD2185W 21 in. LCD Television
Model 2100 FPD2185W Monitor Will not turn on or seems as if its getting power but screen flickers on and off. Seems as if its in reset mode every 3 seconds. Any help is of utmost wanted.
    Problem Solver:
  • 9 Answers
It's very likely a problem with some of the capacitors in the power supply area. You can search for similar fixes here on this site. I'm ordering parts now for mine. Two of the eight tall/blue capacitors in a bunch have tops that are bulging (but I'll replace all eight since they're cheap). There's a pair of two in the middle of the same board on mine with bulging tops and there are four transistors in that same area that look like they got too hot. Most people seem to be getting away with only replacing the bulged capacitors but here is my total part list from digikey.com:
785-1106-1-ND quantity 2 (the D405-marked transistors) 785-1114-1-ND quantity 2 (the D408-marked transistors) P12389-ND quantity 8 (the 470uF capacitors) P12383-ND quantity 2 (the 220uF capacitors)
The total part list is about $7.50 with another $2.50 or less shipping. It's a pain to take apart, given the small connectors inside. The fix assumes you have soldering skills.
Go with these from digikey versus Radio Shack. They're rated for 220 degrees fahrenheit versus only 85 degrees and they're about a third less cost.
Posted on Feb 14, 2011
This may sound kooky, but it works for my similar problem with my Gateway 2100 monitor. It would Flicker (Gateway symbol) repeatedly, and I could not use the power button to cycle on and off. 'sometimes' by itself, it would come on, but it was rare. Finally, I tried taking a hair dryer to the vent in the back, warm up the elements and remove any humidity, and so far it has worked like magic (did not have to disassemble, just blew air through the vent). After about 30 seconds of blow drying the vent, the monitor would turn on. It seems like for my case, whatever element that had a poor connection would heat up enough to make a good connection, and/or if there was any humidity, then the hairdryer cleared it out. Just a though, if you want to give it a shot. It works for me, and saves me from buying a monitor for a while and/or paying for a repair. Cheers.
Posted on Oct 27, 2014
  • Justin Case
    Justin Case Aug 14, 2015
    My guess is that you're moving the hot air around inside the monitor (rather than adding heat). Next time, try just the cold setting. If the capacitors are blown they fail under temperature, lose their expected values and throw off the power supply. When the current runs high the circuitry turns off to save itself.
  • 335 Answers
First, try disconnecting and reconnecting the monitor cable at both ends (pc and monitor). If this doesn't help, the power or inverter board are probably bad. Check with the manufacturer to see if you are still in warranty. If not, you may want to look at a new monitor or see how much Gateway would charge to repair it. Gateway is owned by Acer now, and their repair rates are usually very reasonable.
Hope this helps!
Regards,
Joe
Posted on Jan 01, 2011
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
My screen turns black upon startup. For awhile when my screen was on, it would flicker on and off but remain on. Now, the only time I can see the screen is when I unplug vga cable then plug back in but...
You mention a VGA cable so I assume its a stand alone monitor for a desktop PC.
It can be repaired,this fault is usually indicative of a capacitor, maybe two or three bursting in the
a) Power supply.
b) Back Lighter.
or
C) Inverter.
As its 6 years old, I would suggest replacing would be the most cost effective resolution.
Jun 10, 2011 | Gateway Computers & Internet
MONITORS TURNS BLANK OCCASIONALLY AND THEN COMES SPONTANEOUSLY BACK TO NORMAL. ONCE THE IMAGES STARTED FLICKERING. I HAVE THE IIMPRESSION THAT THE MONITOR NEEDS TO "REST".. THE TURNING BLANK HAPPENS...
it seems to be the power management
right clik on desktop click properties
click on screen saver tab
and from there click on power
ther you can adjust monitor stanby mode
Jul 24, 2009 | Computers & Internet
Blue light flickers, but no picture
I have a gatway fpd2185w the blue light blinks and then dims and the power button dosent work.
Jun 28, 2009 | Gateway FPD2185W 21 in. LCD Television
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
FPD2185W Gateway Monitor
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
1,063 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
