Question about Kolcraft Jeep Sahara Limited Xt Playard
Can't lower side of crib - Kolcraft Jeep Sahara Limited Xt Playard
Where can I get metal rods used to lower bed side
You can't. Drop sides are now banned for good reason. Please do not use this crib if it is old. Nothing is worth risking the life of a baby.
Oct 19, 2014 | Angel Line Jenny Lind Fixed Side Crib in...
How do I lower the mattress on my Bonavita crib quickly?
Most cribs have tabs on the rails of them .... take everything out .. bedding,mattress,etc. Take a look at the platform that the mattress lays in especially the corners.... You might see a hook at each corner that fits into a release tab unlock the realease tab and remove the hook. Do this for each side and reinsert the hooks at the correct level in the crib... If this is not the case you may need to look at the owners manual... But I think you should be able to get a good idea about how it lowers when you remove all the bedding out of the crib..... good luck
Oct 19, 2009 | Bonavita Peyton Crib
Can't lower side of GenAmerica drop side crib
You can unscrew the bolts that allow you to separate the metal frame from the rest of the crib. Once separated, you will be able to work with the rest of the bolts.
Jul 09, 2009 | Baby Gear
Can not get side of crib to come down!
You pull up and push in with you knee on the lower part at the same time.
Feb 28, 2009 | Storkcraft Baby Aspen Stages Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Plastic piece to lower side rial broke
If you have one side piece that works, I would like to buy it from you. Email bluewriter24@yahoo.com Thanks.
Jul 05, 2008 | Childesigns Bellmont Crib
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
CONVERTING TO TODDLER BED
i found this on the simplicity website, hope it helps. i got mine done i minutes!!!!
Remove Drop side.
Lower drop side. Push in on the tabs at the
bottom of both lower tracks to slide the drop
side down off the tracks as shown.
Position Mattress Support.
Mattress support must be in the lowest
position. If not, use the allen wrench to
remove bolts. Lower support into position
and re-attach to headboard.
Remove upper and lower tracks.
Aug 29, 2007 | Simplicity for Children Ellis 4 in 1 Sleep...
Bassett crib sides falling down
You likely are missing the lower track assemblies. Part # CC (right) and DD (left). These screw into the lower inside legs on the side with the drop down rail to secure the rail from dropping off. See instructions, Step 1 and Step 2.
Call Bassett 1-276-629-6000 to obtain instructions and a parts list for model # 5926-0504 (look on the inside headboard - not the gold label).
Parts can be ordered from Products America 1-800-772-1041
May 29, 2007 | Bassett Parson Ridge Crib
Kolcraft Jeep Sahara Limited Xt Playard Logo
47 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Jennifer Rock
Jennifer Rock
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
