Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool dishwasher washer stops working then makes a buzzing sound. thought it might need some rinse aid but doesnt work!
  • 95 Answers
It sounds as if your motor is locking up. Check under the front lower panel, snd see if there is water leaking into the motor, the motor simply seizes, and needs aspot of grease. You may also need to reprime the washer. To prime, Slowly advance the timer at start-up, After a few clicks, you will here the water valve open and start to fill the tub, then let the washer do it's thing.
Posted on Jul 08, 2008
Wont do anything
See if the buzzing is coming from the timer, it may be broken. Try to change the timer to spin and see if the motor works.
Dec 02, 2013 | Maytag MTW5700TQ Top Load Washer
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
The machine works fine until it reaches the rinse cycle.
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Bosch SHY66C05: interlock broken, dishwasher rinse-aid leaks, and soap does not open (sometimes)
door lock is in the wrong position. open door and use 2 small screwdrivers to lever lock to correct position. bend the hook on the cabinet slightly downwards if it is a metal hook
rinse aid and detergent dispensors are 1 item. could well be faulty but can also be module. check you are getting volts to the solenoid at appropiate part of the cycle
Sep 06, 2008 | Dishwashers
My machine will not rinse cloths. The cycly stops once it gets to rinse and it makes a lite buzzing noise.What could it be?
Most washers today are cold rinse only. The buzzing noise you hear may be the cold water valve.
1. Check cold water to make sure it is on.
2. Remove cold water hose from back of machine. Inspect washer cold water valve for debris. Can usually be cleaned with spray bottle with hard spray.
3. Cold water valve has failed.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Jun 22, 2008 | Washing Machines
My washer is making a buzzing noise and stopping the process.
Yes sounds like the drain pump or sump area is clogged. Axcess throug lower service panel if the model you has selected is accurate..
Jan 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dishwasher problems
Hi Bmissy,
I had the same problem with my dishwasher. In my washer the problem was caused by a buildup of water deposits throughout the machine. I increased the temperature of the water, used three bottles of "Dishwasher Magic" and now my machine is working well. I read that the rinse aid dispensers do not disperse enough of the product for extremely hard water, the solid rinse aid dispensers work better. I know that adding a little water softener to your washer when you run it can help. If you can't find "Dishwasher Magic", you might want to try running your dishwasher with a few quarts of white vinegar to remove the deposits on the coil. You may need to clean out the deposits in your washer regularly to keep the machine working well.
HTH!
Ann
Nov 02, 2007 | Dishwashers
My washer washes, but doesnt rinse...
I sounds like it needs a new timer.
Oct 08, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal De
