Question about Brother CS6000i Computerized Sewing Machine
Hi, my tension is loose, and I have tried to adjust it, but can't get it set just right. any suggestions? Thanks
    Genius:
  • 1,788 Answers
I have mine set at 3, if you are talking about the top thread tension. Try that.
Posted on Jan 02, 2011
Can't get the tension set right. bumps on top
Means thread is way too loose. Up tension dial number until the thread just skims the surface of the fabric.
Feb 16, 2015 | Sewing Machines
Left needle thread is too loose on toyota overlocker
check to see if the needle is inserted correctly
make sure it's the right needle for the machine
try adjusting the tension setting to a higher number or letter
if that doesn't work, I suggest taking the machine in to be checked
Jul 29, 2012 | Toyota SL3487 Sewing Machine
Top thread too loose, brings up bobbin thread. Tried to adjust, but cant get it right. Have manuel, but cannot locate it currently I have The Omega model
Hi. If the bobbin thread is coming up on top, then the upper tension is too tight. Try loosening it.
Hi. The best way to adjust your tension is to use good-quality thread, a size 12 needle, and different color threads in the bobbin and on top. That way, it's easier to see which thread is loose. Sew a few inches, check, and adjust (make sure the pressure foot is DOWN). Stitch a few more inches, recheck, and adjust some more. Just move the adjustment knob a little bit each time.
You might also want to use a bit of unwaxed dental floss and floss the tension disks. That helps get rid of any old lint and pieces of thread that build up in there.
As a last resort, you might need to adjust your bobbin tension. There is a very small screw on the bobbin case that tightens/loosens the spring/lever. If you need to adjust it, only move the screw a tiny bit. But, like I said, this is only a last resort--almost all adjustments can be done by adjusting the upper tension.
Hope this helps!
Robbie
Aug 12, 2010 | Necchi 6015 Mechanical Sewing Machine
Sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
I need to know how to adjust the bobbin tension on my euro-prox sewing machine.
There is a tiny screw on the side of the bobbin case.
Mark the **** (in the screw head) position on the bobbin case with tiny dab of nail polish so you will know where the original setting was.
Left/loose and right/tight.
If you are adjusting because the bottom stitching is loose/loopy, first try threading the machine with the presser foot up to see if this solves the problem.
May 01, 2010 | Euro-Pro Shark 60 - 384
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Euro-pro 464xc bottom tension loose
Welcome to FixYa!
Loose bottom stitches come from the top, not the bottom. Seems weird, but that's the way sewing machines work.
The dial tension should be set at the mid range and make absolutely sure that you have the machine threaded correctly. Both things will cause a sloppy bottom stitch.
Thanks!
If you find my solution helpful, I'd appreciate a FixYa rating....
Jan 15, 2009 | Kenmore 12102
Simplicity 4 thread EZLock 880 pressor foot settings
Easiest way to get the tensions right, use 4 different coloured threads
Make sure the tension disks are clean........run a length of fabric in a see saw fashion through each tension unit.
....set all the dials to 3 or 4 then sew test.......take a look at what needs attention, make a small adjustment and test/adjust until the needle threads are firm and the looper threads meet neatly at the edge of the fabric with just the absolutely tiniest hint of being loose.
Jul 16, 2008 | Sewing Machines
White w750 sewing machine
I would suggest removing all of our thread and rethreading your machine. Put the thread tension at medium. Try a few stitches. If they are unacceptably loose or tight, try loosening or tightening the bobbin's tension. To do this, locate the tiny hole at the front of the bobbin area. This hole is on the outside of the machine. This hole lets you have direct access to the bobbin's tension screw, so find a tiny screwdriver and turn the screw inside the hole a little to the right for tighter tension, or to the left for looser tension. Let me know how it works - I love this sewing machine!
Dec 11, 2007 | White Sewing W750 Mechanical Sewing...
Brother CS6000i Computerized Sewing Machine Logo
100 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
