Question about KitchenAid Classic Stand Mixer
The head of the mixer is vibrating (shaking) a lot when mixing. It does this so much that I feel as though I need to hold onto it when it's mixing. If I turn it on without the bowl and just run the beater, it runs smoothly. But when resting on the bowl bottom all 3 of the beaters cause the shaking. this has been going on for about 2 weeks and so we have limited its use as much as is possible.
    President:
  • 1,102 Answers
I am sure you are locking the tilt head in the down position when your using it right? If so then check to see if the beaters are hitting the bottom of the bowl. If they are then there is an adustment screw that sets the height of the head in the down position.
Posted on Jan 01, 2011
Kitchen Aid HDPro 5 quart bowl lift mixer is making clunking, rattle type noise when mixing anything heavier than egg whites.
You are probably going to have to remove the top housing and look and listen while it is running. Does it lose drive when it is being noisy? You need to remove the back cover, the silver band with Kitchen Aid on it and that will expose the 4 screws holding the housing on. Remember fingers and tools OUT while it is plugged in or running. I can't be a lot more help to you, we don't have that model in NZ.
Mar 07, 2014 | KitchenAid Professional Heavy Duty Series...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
The rotating head on the mixer keeps falling off. how do you get it to stay on? it comes off when were mixing.
The Planetary plate comes attached to the shaft from the factory. It is not supposed to get
loose and come apart but it often does due to the mixer's vibrations and the user's constant
attaching and removals of the flat beater, wire whip or dough hook onto the beater shaft.
Try to remove the Planetary plate first : Gently rock it from side to side while pulling on it
to separate from the shaft. Notice the groves on both the shaft and inside the planetary
housing. That is how they are attached to one another at the factory (just friction, no screws
or pins). Now for a permanent solution:
Take a trip to Home Depot or Ace hardware and buy the J-B Industro Weld Compound
(Not the 5 minute type). Mix an equal amount from both tubes (Black and Red). Use a Q-Tip
and apply a thin layer of the mixture on both the shaft (grooved section) and inside the
planetary housing. Now re-attach the planetary plate to the shaft. Use a long strip of duct tape
to hold the plate in place (to prevent it from falling back out). Allow the epoxy to dry overnight
or at least for 8 hours.
The Planetary assembly is now permanently attached to the shaft of the mixer.
Jun 10, 2011 | KitchenAid ProLine 600 Stand Mixer
Head of mixer is loose what do I do?
Feb 12, 2011 | KitchenAid KP2671 Professional 6 Series...
The part of my KitchenAid mixer that hold the motor shakes violently when I use it. What can we try at home to fix this problem before going to repair shop? Thank you, Gillian Lukes
Hi, W/D here.
Try this:
1. Lift the mixer head, tilting it back.
2. Locate the large silver screw under the head, where it connects to the base. It will have a slot in it, for a standard slotted screwdriver.
3. Tighten the screw up.
Best regards, --W/D--
Please feel free to rate this solution. Thanks.
Feb 04, 2011 | KitchenAid 32685 Mixer
My mixer is a lift-top and the top seems to be loose and wobbles as it mixes. help?
Hi, W/D here.
If you raise the head of your mixer, and look under the raised part, you'll see a silver screw head with a slot for a standard bladed screwdriver. Tighten that screw, and that should do it.
please feel free to rate this solution!
Jan 31, 2011 | KitchenAid 32685 Mixer
Vibrates and beater hits bottom of bowl
Try adjusting the height of the head by turning screw #36 counterclockwise a turn or so. This will raise the mixing head so the beaters no longer hit the bottom of the bowl. Refer to parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
If the pivot pin #18 is not centered and secured then center the pin and turn the mixer on its side to tighten screw #31 from underneath the mixer to secure the pivot pin.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My kitchenaid mixer has a large amount of vibration when used on speed 4. So much vibration that the head pin was vibrating out of place.
If you tip the entire unit on it's side you'll find a screw holding the pin described above in place. Take a flat head screwdriver and tighten that baby up. You'll be all set.
Nov 15, 2009 | KitchenAid Food Mixers
The pin that holds the mixer to the stand keep working it's way out when I mix dough.
Hi, Mixing Dough is tough. the neading hook really works hard and the pin will like to wander out on the left side of the mixer "right side if your facing the it". What I did was find an smaller elastic band and with the pin sticking out a 1/3 of an inch from the opposite side from which it wanders out.
loop the band on it as many times as possible so its stays on tight . with this you now have a bumper and as the pin vibrates to wander out the elastic bumper will gently keep pulling it back during the vibration cycle keeping it in check .
Works perfect but still inspect the pin and bumper before each use.
Mike
Aug 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Classic Stand Mixer Logo
723 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
