Could you tell me where i can get a instruction manual for central heating thermostat Lifestyle Model Lp722
  • 2,133 Answers
Try with this:
cgi.ebay.co.uk/...MANUAL...LIFESTYLE-THERMOSTAT-/200541444128
Helpful?
Posted on Jan 02, 2011
I need programming info for an Altech model ALTHC001 central heating and hot water programmer
Can you please tell me how to set clock for central heating the clock is an althc001 had power switch off and when it was turn back on the clock is not working when the boiler is calling for heat and the same with the heating can you help
Oct 07, 2011 | Honeywell Programmable Thermostat Heater
My central heating pump does not switch off when the acl lifestyle model lp722 central heating timer switches both the hot water and c/h off. pump keeps running through the night
if you can turn off the hw and ch off , to the off postion and it shuts off then the acl lifestyle could needreplacing mine did the same on ch only so changed mine , or check the divtervalve is working and not stuck in the open postion , try turning hw on and off only then the ch see if valve works
Jan 08, 2011 | Heating & Cooling
Cannot set timer on central heating/water system.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jul 27, 2010 | Honeywell Heating & Cooling
My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Nov 18, 2009 | Honeywell Electronic Programmable...
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
437 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
