Question about Hitachi C21-F200 21" TV
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
    President:
  • 2,992 Answers
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Posted on Jan 01, 2011
TV Input Signal
Check to see if rear audio/video inputs work or not--DVD player etc.
If they do you may have a bad tuner in the set--a option would be to use a box if those work connected via one of sets of audio/video inputs on rear of set---bypass the tuner.
May 30, 2012 | Televison & Video
I forget hoe to connect my jvc dvd digital theater to my television. I own a Philips 32" lcd tv. How do I do this. I also have a digital box that it has to go through.
can you post me the model of your dvd theater, I can look up the instructions for you. also the model of your philips tv would be helpful so I can find out what connections both devices have, for best results.
Sep 21, 2008 | JVC Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Why won't dmr e85h pick up all the digital channels the tv attached to it will? Is it outdated technology? Do you need a digital set top box or completely replace the unit? Anyone...?
You most likely will need a set top box connected to this recorder in order to receive digital channels, Assuming the DVD recorder works besides this detail, you should not need to replace the unit. Only replace it if it DOESN'T work.
The DMR-E85H is a 2005 model so it is more than 5 years old.
Mar 13, 2011 | Panasonic DMR-E85H DVD Recorder
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
Jul 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Sylvania DVC850C after the February conversion
Simple answer is no.. not if it does not have a freeview tuner that goes for all those recorders out there that are not digital you could of course attach a freeview set top box to it but in my opinion with recorders being literally dirt cheap these days it's not worth the bother
Nov 29, 2008 | Sylvania DVC850C DVD Player/VCR
Converter box
the digital box has to hooked up the rca plugs on the bac of the vcr if you want to use the vcr (you will only be able to pick up channels throught input and the box will have be set on the channel you want to record. You need a switch to hook the vcr and dvd player both up. the atenna cord can be attached to the back of the convertor box then attached to the tv.
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
Copying video from camera to DVD Recorder attached to TV
You can visit this link for any information related to this camcorder http://esupport.sony.com/US/perl/model-home.pl?mdl=DCRHC90®ion_id=1 This also allows you to download the user's manual. Cheers
Mar 07, 2007 | Sony Handycam DCR-HC90E Mini DV Digital...
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Hitachi C21-F200 21" TV Logo
171 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
