Question about Kenmore Washing Machines
80 model series wont go into the wash cycle and does not stop filling the tub with water causing it to over flow
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Check the pressure switch and the lines going into it for blockage. The video below will walk you thru the process.
Posted on Jan 01, 2011
Testimonial: "very good video but how do i take the washer apart"
  • 1 more comment
  • Richard Roth
    Richard Roth Jan 01, 2011
    Here is a video to show you how to open the washer. The washer model is different but still opens the same.
    Happy New Year!
  • fritolay555 Jan 02, 2011
    thank you so much i did just what u said and that fixed the problem , great way to start a new year. Happy New Year to u and all your family GOD BLESS you all for all the help u provide to us.
  • Richard Roth
    Richard Roth Jan 02, 2011
    Your quite welcome! You have a great New Year too!
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
It's a model 110, series 80. The water doesn't stop and it over flows. The machine doesn't start the wash cycle
If your washer fills, won't shut off and then overflows, this is caused by either a pressure switch malfuction, or a water inlet valve that won't shut off. The following link explains how to diagnose the problem and replace any parts (if required):
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I know the link is for a problem where the washer continues to fill even when it is not in use, but this problem occurs while the washer is running as well. The method of determing the cause is the same.
In many cases, an overflow problem is caused by the air hose slipping off the pressure switch. Without the air hose, the pressure switch never detects the pressure differential from the wash tub as it fills and won't shut off. This causes the washer to overflow and appear as a more serious problem.
Read through the link provided and let me know if you have any questions. If the conditions I have described do not match your symptoms, please post back and elaborate a bit more so I can help you determine the source of the problem. Please include your complete MODEL NUMBER. I hope you find this information helpful.
NOTE: "110" is the manufacturer code, which identifies the manufacturer of your washer as Whirlpool. Please include all the numbers that follow these first three numbers in order to properly identify the model of your washer. The model number is located on a nameplate along the wash tub rim under the lid.
Mar 29, 2010 | Washing Machines
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer over flows
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore washing machine 80 series
    check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
    if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
    Oct 14, 2007 | Washing Machines
    Washing Machines Logo
    88 people viewed this question
    Sal DeAngelo
    fordexpert
     Brian Main
    Brian Main
