Question about PfaFF Creative 7570
HARD DRIVE MEMEORY
I TURNED ON MY MACHINE AND TO MY SUPRISE THE SCREEN WHICH HAS ALL THE STITCHES IS LIT, WITH OUT STITCH NUMBERS, CHANGED BATTERIES AND NOTHING. PLEASE HELP.
GLORIA
    Scholar:
  • 41 Answers
Hi Gloria,
Unfortunately, it sounds like you may have a computer board that's gone bad. Rare, but does happen and not something you will be able to repair yourself. There are a number of computer boards in the 7570.
I would suggest calling your local Pfaff dealer (if they are someone you trust) and having them check it out. If you're not pleased with your local dealer, you may find another dealer close enough to you to warrant the trip.
Best of luck getting your machine back up and running - we know how awful it is to be without!
Best,
Kim & Linnette
Posted on Jul 16, 2008
I have a new elna 860 expressive today when I switched it on only some of the icons are lit up, the straight stitch and tea shirt icons. On the straight stitch setting only the top 4 icons are lit
Is it "brand new," ie just purchased from an Elna dealer? If so, take it back immediately! It is still covered under warranty.
Possibly some of the computer components are failing. This, most often, requires professional service.
Jun 14, 2016 | Elna Sewing Machines
SINGER XL1000 SEWING MACHINE
Hi Peggy,
I know this want be easy for you.  I need any kind of part number you can get off the LCD screen.  Is it a display and you type the different stitch stuff into a keypad?  Or , is the LCD a touch screen that you touch the screen to select a stitch?  I do not have one of these Sewing machines, but I do Electronics repair. Is your Screen Black and not displaying anything?  I believe we can work through this and get you a repair solution. The back light may have gone out on the screen only. Please reply with more info, so that we can get you a solid solution.  By the way, Singer really does not make those anymore.  They are making a more modern Screen at this time. Usually after 5 years, the manufacturers stop making parts for a model. Good news though, we can work on repairing the one you have. Go to Ebay and see if we can buy a XL1000, or other venue to rob the parts from.
Oct 13, 2007 | Singer Quantum XL-6000 Computerized Sewing...
Why won't it do decorative stitches?
Have you selected the proper stitch. Look at the decorative stitch line 1,2,3,or 4, then the number above the stitch. Your screen should say 1:24 for line one, stitch 24. Make sure you are using the recommended foot. Embroidery unit is disengaged. Then makes sure you have selected the proper weave or thickness of material button. If it still won't sew, try a different type of fabric button and try that. This will change the tension. The tension could be too tight or too loose for that stitch.
Sep 08, 2014 | Sewing Machines
I have an elnita 255 and bought it brand new way back when...the problem I have is I can not get this machine to do a baste stitch. since I bought the machine new it has never done basting. Even when I...
The straight stitches can be shortened and lengthened utilizing the length selector. If you are attempting to do this with zigzag the stitch will be the same distance but the fabric will appear as if the material hardly moves. This will be changed by using a wide stitch. If you can't truly get a different stitch length on the straight stitch you may need the feed dog adjusted by a pro so that it will give you a longer stitch.
Nov 29, 2017 | Sewing Machines
Almost jammed
This sounds like a bearing failure, I would take it in to a service center and ask for a free estimate.
May 25, 2010 | Singer 7442 Mechanical Sewing Machine
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Probably a bad circuit board. It needs to visit a Pfaff dealer for diagnosis and repair.
sewman7
Jul 08, 2008 | PfaFF Creative 7570
HARD DRIVE 7570
Ask this tech kimbo322
An ex- PfaFF employee
Post your question to that tech
Came without an instruction manual
You should be able to buy an instruction manual from Janome or even on ebay.
Jan 21, 2008 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
91 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
