Question about SPL Audio DK4-680 Car Audio Amplifier
I have an SPL DK4-680 Phantom Series amp powering my mids and highs. The amp has power and has an indicator light on. It is red at the moment which states it is protected, if green then it would perform. Not sure how to get it switched or what would keep it from working. When I originally hooked it up, everything worked just fine. Since then the vehicle has sat for a while and I changed the battery. Thanks.
3 Suggested Answers
  • 245 Answers
SOURCE: power light turns from green to red protect mode and then there is no sound coming from my speakers
there are 2 reasons for it to be going into protect mode 1 is heat 2 is the load on it. if it is going into protect mode soon after it starts there is a problem with the speaker. if it is after it has been on for a while it is that the amp itself is overheating. hope this answers your question
Posted on Apr 27, 2009
  • 108 Answers
SOURCE: the fuse blew on my
Did you put a new fuse in it? If you didn't then put a new fuse that is rated at what the amp calls for. If you have and the light stays on, then odds are there is a broken wire inside and the amp needs repairing or replacing.
Posted on Jul 12, 2009
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
I have a SPL phantom dk-3400 car amp and when i
Even withou the help of any diagram you have a visual indication. Look inside to the area of the burn. identify the component. check around the burned area for the cause of the burn. it could be the failue of the output or the power side. equipped with a multimeter you must be able to identtify stage by stage the short of the circuit. remove, replace and test. afterwards connect the woofer - check if your woofer coils are damaged too- Hope this helps? Good day
Jul 12, 2010 | SPL PHANTOM DK-3400D Car Amp
I have spl crm520-2 amp and the light does not go on
power supply is bad spl is not a good compane i would replace the amp
Jul 06, 2010 | Car Audio & Video
When i turn the amp on the light turn red and it goes off no green light g the amp was getting hot shotting down
when you hooked the amp up did you make sure your speakers were all in-phase positive to postive / etc.. a common issue with hi-power equiptment is grounding whatever input power supply gauge wire was used the ground has to be equalized, also if youre drawing too much on the amp (too much speaker/not enough amp ) this problem will continue till the amp cooks, check all phase, and if youre mono-bridging make sure this amp can be mono-bridgeable that would also send an amp into protection mode because its recognized as a short to positive-good luck
Jan 17, 2010 | SPL Audio Phantom DK2-1000 Car Amp
No sound
unplug spkr from amp and leave rca and turn if this dont happen again check you spk
if it does happen again unplug rca and turn on and if this happen your amp may be bad
May 17, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Power light turns from green to red protect mode and then there is no sound coming from my speakers
Apr 27, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Exploded 5 resistors need a schematic
I don't have the schematic but if you can send me a photo of the inside of the amp, I may be able to tell you the values of the resistors. Many of the class D amps are clones.
babin_perry@yahoo.com
Oct 02, 2008 | SPL DK-2600D Car Audio Amplifier
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Sep 09, 2008 | Car Audio & Video
Car amp
The 2 + and 2 - connections are the same, just split into two. This is usually because, for high power amps, it's easier to route two 4 AWG wires than it is one 2 or 0 AWG wire. Both "+" will go to your battery (through a fuse block, of course) and both "-" will go to a grounding point.
Mar 10, 2008 | SPL Phantom DK2-1000 Car Audio Amplifier
SPL Audio DK4-680 Car Audio Amplifier Logo
54 people viewed this question
Top SPL Audio Car Audio & Video Experts
xxxxxx xxx
Are you a SPL Audio Car Audio and Video Expert? Answer questions, earn points and help others
