Question about Mitsubishi WS-55515 55" Rear Projection HDTV
My rear projection tv went suddenly mute while I was watching regular cable tv. A "mute" message appeared without me pressing any buttons on the remote. I pressed the mute button on my tv remote and my cable remote and neither matched the "mute" message that just appreared on my screen briefly. I went into net command - everything seems to be in order. I pressed device menu and ran my dvd player and the volume worked fine on the tv. I am not sure what to do - help?
  • Ed Vodegel Jan 06, 2011
    Thanks for your thoughts - the problem was not the SAP but a phone line issue from our TV provider.
    We called them and they said this may happen on occasion w/ their service. They corrected the problem on-line and the volume works fine now.
    Ed Vodegel
  • 10,515 Answers
I believe the reason you do not have sound on these channels is that somehow the
SAP button was pressed. The SAP is "separate audio program" it is used to hear
the program in a different language if available. If the SAP is turned on and that
channel is not broadcasting a SAP signal then you would have no audio.
I am not sure on a universal remote which button , would be used to change the audio
settings. You may be able to access the settings from the menu button on the TV.
Go to one of the channels that has the problem, press the menu button on the set
and look for Audio settings, switch the audio program from SAP to normal audio.
You would have to do this for each channel that has the SAP displayed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 02, 2011
  • taran_2005
    taran_2005 Jan 06, 2011
    Thanks for your response!!
    Glad that it was fixed.
    Any further assistance, revert and i would be able to follow up from there.
    Thanks and Regards
    taran_2005
    Ps - Do accept this solution,if you find it to be of any help so that i could get the credit for my time.
Samsung HCL4715w Hdtv convergence issue
Maybe you can fix it in the service menu.
Turn off TV, press mute then 182, Turn on TV and check out new menu items
Jan 24, 2013 | Samsung HCL4715W 47" Rear Projection...
The sound on my TV went out all of the sudden. I was watching TV then all the sudden it was like the mute button was hit. The first thing I did was press the mute button a few time, still no sound. Second...
You should take the TV back to Bestbuy when you get the chance... Tv could of came defective from the factory. They should be able to exchange for a new one if you explain the problem to them.
Jun 30, 2011 | Dynex DX-LCD37 TV
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
I have a Toshiba 57H81 57 in. Rear Projection Television. The picture started having "squiggles" in it, which at first went away after the T.V. "warmed up". Now they appear to be...
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replace on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H82 convergence problems. TouchFocus
See my solution <http://www.fixya.com/support/t2795690-convergence_off_blue_line_only_vertical>.
You need to get to the service menu--it's been 4 years so go to AVSforum.com to turn off the different guns and get the better pattern.
At your risk: To get into Service mode:
1. Turn your TV on. 2. For X81 or earlier series: Press MUTE on your remote and release. 2. For H80/H81/HX81 series: Press MUTE on your remote and release two times ("Mute" on-screen) 3. Press down MUTE on your remote again and hold. While holding, press the MENU button on your TV set's front panel. 4. Release both buttons. 5. An "S" should appear on your screen. Press MENU again on your TV. 6. Now you're in service mode. Channel Up/Dn - Scrolls through Parameters and Volume Up/Dn - Changes Parameter Value
To get into convergence mode:
Get into Service mode, then Hit '7' to bring up the convergence grid. Buttons 100, 0, and ENT control which gun you want to turn off (if you want to align the red to the green without seeing the blue gun and other variations). 2=up, 8=down, 4=left, 6=right, 3=change gun to converge, 5=converge that point. To exit convergence mode you press 7 once and your screen should look like it's imploding then return to normal and then you press 7 to get back into regular service mode.
I have more info found on the board. -Ken
Jul 31, 2009 | Toshiba 57H82 57" Rear Projection...
Lamp rest light
Press and hold the Mute button on the remote and at the same time press the Enter button on the TV until the Reset menu appears. Press Center button on remote to clear hrs. Your done!
May 27, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have a magnavox projection tv...picture /no sound
I put new batteries in the remote and reset the cable box.
Mar 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV
If you are using cable and the signal is connected to the TV through the regular cable wire, then the TV must be in TV mode to work properly. If you are using a cable box with that TV then the TV must be on channel 3. If the screen shows AV 1, then the TV is in the AV mode (red, white and yellow RCA jacks), and you most likely accidently hit the INPUT button on the remote. Pressing 0 3 or INPUT a couple of times on the remote should bring your picture back.
Aug 09, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Mitsubishi WS-55515 55" Rear Projection HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
