Question about Gateway (5500778) Internal 32x CD-ROM Drive
Device cannot start code 10 dvd drive - Gateway (5500778) Internal 32x CD-ROM Drive
  • Gateway Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager you could see a red x,or a yellow !,? either of these means that you will have to uninstall then reinstall the program and its drivers
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
If the ntdll.dll error only displays when you use a specific software program,
uninstall the program, reboot your computer, and then install the latest version again from scratch.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 01, 2011
My TS-L 632H DVD Rw drive will not recognize cds. Get the following code on Device Manager: This device can not start (code 10)
firstly u need to check your cables then try different cds, there are sometimes when an optical drive does not read some cds or dvds mainly dvd RW .
the only solution for it is changing the lense of the drive or buying a new one
happy computing
good day
Jun 01, 2010 | Computers & Internet
I have a slimtype dvd a ds8a2s a ata device that I get a code 10 device cannot start message in device manager I have tried to re-install the driver and downloaded any updated drivers and get same message
From your description I understand that the DVD drive is not working and you have code 10 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Jan 10, 2010 | HP Compaq Presario CQ60Z Notebook
Optiarc DVD RW AD-5170a ata device. Cannot start code 10 error? any ideas why.
Possible cause of the problem:
1. Error 10 means that the drive driver is not properly or not installed in your computer.
2. You drive is broken.
Solutions:
1. Replug your drive wiring's inside the computer casing.
2. Check in the Device Manager in your computer if there is conflict in your drive. Go to Control Panel/System/Hardware/Device Manager to do this.
Nov 28, 2009 | Gateway (5500652) (  5500652)...
Acer Aspire M1610 with MS Vista SP2. DVD unit code 10 error
Right click on the dvd drive and select uninstall, the right click anywhere in the window and select scan for hardware changes (or to that direction)
The computer will re-install the drive automatically, if the problem remains follow these instructions
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Sep 11, 2009 | ASUS Computers & Internet
Dvd drive
Remove the drive in device manager, and restart your computer. This will reinstall any necessary drivers
Apr 12, 2009 | Sony Computers & Internet
Stop working
Code 10 could mean either the driver has gotten corrupted: repair for this is to reinstall the driver; or it could mean the drive itself has come to the end of it's lifespan; repair for this is to replace with a new drive. Before buying a new drive check all cables going to the drive to see if any came loose, and reinstall the driver. If this does not work you will need a new drive. Hope this helps & please take a moment to rate my solution. Thanks.
Feb 23, 2009 | Pioneer DVR-107D DVD±RW Burner
Matshita DVD-RAM UJ-8502 ATA Device connot start
Usually this code means either a cable is not connected correctly or the driver is not present or corrupt. Try downloading the latest driver from the manufacturers website. Hope this helps.
Jan 09, 2009 | Toshiba Style Bay DVD-RAM Drive Kit...
D drive cannot start
Your problem could be as easy as right clicking on your DVD drive, Click properties, and see if your drive is active.
Oct 28, 2008 | Computers & Internet
Optiarc cd-rw crx880a ata device: This device cannot start. (Code 10)
Did you try to click "Troubleshoot" on the page that reported "cannot start" ?
Did you try to click on the device, and choose "uninstall" ?
Then, rebooting Windows should cause Windows to "find new hardware", and properly configure the DVD/CD drive.
May 22, 2008 | Microsoft Windows Vista Ultimate Edition
Gateway (5500778) Internal 32x CD-ROM Drive Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
