Question about Video Game Consoles & Games
I have the motorola sbg6580 but cannot connect to my psp, It says access point not detected. I have my pc, laptop and wii and dsi all hooked up and have no problems........can you please help
nliwilson
  • 114 Answers
SOURCE: wireless won't connect.
First and foremost check that you have WiFi switched on, it sounds so simple but you'd be surprised how often this is the problem. The WiFi switch is on the left-hand side as you look at the screen and needs to be in the up position to be on. A quick note about WiFi security; WEP is useless, even 128bit, freely available 'stumbling' software can crack a WEP encrypted network in as little as 20 seconds (depending on network activity). You need to use WPA or if you're OS supports it WPA2. Hiding you're SSID makes no difference as you're router still transmits and is therefor still visible, it just doesn't respond to access point requests. MAC address filtering is useless because once your network has been found all MAC addresses are visible. These days 'stumbling' software even automates the task of masking one MAC address over another. Although using as many layers of security as possible can help to keep nosy neighbours out WPA (and preferably WPA2) really is the only thing that will slow losers with nothing better to do down long enough for them to get bored.
Posted on Aug 11, 2007
  • 55 Answers
SOURCE: psp internet problem
You need to enter the wep key, ONLY if you have wep enabled on the wireless connection.
Posted on Sep 16, 2007
SOURCE: PS3 can't detect access point
i have some solutions..
1. if there's lots of walls between the router and your ps3 it may not detect the signal. i had a very weak signal until i moved some stuff around.
2. you can manually type in your wireless name and i think it should at least reconize it, and maybe connect.
3. make sure theres no firewalls or anything to block other connections from entering your signal.
thats all i can say, sorry im not a tech guy-only 17!
Posted on Dec 27, 2008
  • 10 Answers
SOURCE: the internet is not working
You have to get the ip adress and the security code frm the computer your acessing. in other words, you need a computer to hook it up to and use its internet connection.
Posted on Dec 31, 2008
SOURCE: my PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
Posted on Apr 25, 2010
My dsi wont connect to my access point
Aug 10, 2011 | Computers & Internet
How do i conect my dsi to internet
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Jul 19, 2011 | Nintendo DSi White Console
How do you hook it up to internet
    • 1 You must either have broadband internet access and a wireless router or you can connect your Nintendo DSi at a hotspot, such as a library or coffee shop that offers internet access. Make sure you are in a location mentioned above before going to step 2.
    • 2 Turn on your Nintendo DSi and click on the wrench icon. This will take you to the system settings.
    • 3 Go to page 3 and select "Internet".
    • 4 Click "Connection Settings".
    • 5 Click "None" to the right of "Connection 1".
    • 6 Click "Search for an Access Point".
    • 7 Look for an access point that has a gold lock that is unlocked. Select that access point and your Nintendo DSi should now be connected.
    • 8 If you are planning on playing games online with your Nintendo DSi and have WPA security, you will have to set your router to WEP security.
      To do this, get back to the "Connection Settings" screen mentioned in step 4.
      Click "Advanced Setup".
      Click any button that says "none".
Jun 15, 2011 | Nintendo DSi Black Console
What website do you go to to donload inernet on your dsi
Just to clarify your concern you want to know on how to connect your dsi to internet?
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • If in instance you want to know on how you can download games for your DSI, just follow the link below.
    http://www.nintendo.com/wii/channels/nintendochannel
    Mar 23, 2011 | Computers & Internet
    How do you hook up the internet
    Prerequisites:
    • A Nintendo DSi or Nintendo DSi XL
    • A broadband internet connection in your home, such as cable or ADSL
    • A wireless router / access point
    • You can also use a free public WiFi connection such as those found in McDonalds restaurants
    Step by step instructions:
    1. Switch on your Nintendo DSi / DSi XL
    2. Click on the spanner icon to access - System Settings
    3. Select - Internet, on the 3rd page of - System Settings.
    4. Select - Connection Settings and tap the - None bar in - Connection 1
    5. You have 2 options here, you can setup a connecion manually or you can scan for available connections. The easiest option is to scan for an access point, select - Search for an Access Point
    6. The DSi / DSi XL will list the names of any access points that are in range. A yellow unlocked icon next to the connection name denotes an unlocked WEP connection. A locked yellow icon denotes an encrypted WEP connection that requires a WEP key or password to be entered
    7. If you are accessing an encrypted WEP connection, enter your WEP key now
    8. If the WEP key is correct, you should now be connected. Test your connection to verify this
    Mar 06, 2011 | Nintendo DSi XL Burgundy
    How do i use my nintendo points card
    You need to start the Wii Shop channel, and redeem it there. Or if you are on a DSi, the DSi Shop channel.
    Here is more detail;
    To redeem a Wii Points Card:
    Access the Wii Shop Channel through the Wii console's Channel menu.
    If this is your first time using the Wii Shop Channel, read the User Agreement and click "I agree" if you understand and agree to the terms. Click "Okay" after reading the Wii Shop description
    Once on the "Welcome to Wii Shop Channel" screen, select "Start Shopping."
    Click the "Add Wii Points" button.
    Select "Redeem Wii Points Card."
    Scratch off the silver area on the back of the Wii Points Card to reveal the Wii Point Card's activation number.
    Enter the activation number into the space on the screen.
    Select "OK" to continue.
    If you want to redeem the card, select "Redeem".
    Once the purchase is processed, a confirmation screen will appear indicating that Wii Points were added to your Wii Shop account.
    How to use Nintendo DSi Points and download DSiWare items
    The Nintendo DSi Shop is available by selecting the Nintendo DSi Shop icon from the Nintendo DSi main menu.
    On the Nintendo DSi Menu, use the stylus to select the Nintendo DSi Shop icon.
    Select "Start Shopping" to reach the Nintendo DSi Shop main menu.
    Select "DSiWare," then select from the following options:
    Free Search for free software
    200 Search for software that costs 200 points
    500 Search for software that costs 500 points
    800+ Search for software that costs 800 points or more
    Find titles Search for software by publisher, genre, title, etc.
    A list of titles matching the selected criteria will be shown.
    Select the desired game or application, then select "Download" or "Free," then select "Yes" to begin the download.
    Jan 07, 2011 | Computers & Internet
    Activate internet
    Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the psp" button. Now, select "psp Settings" to access the "System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours Select "OK," "Save Settings," and then "Yes."The psp console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the psp will begin to download any available updates.
    Dec 24, 2010 | Sony PlayStation Portable (PSP) Console
    How do i connect the internet to my DSi?
    1. Turn on your Nintendo DSi and access your system settings by clicking on the wrench icon.
    2. Scroll over to the third page, and select "Internet."
    3. Now choose "Connection Settings."
    4. Click on "None" in "Connection 1."
    5. Then click "Search for an Access Point"
    The system will then display the name of any wireless access point within range.
    If The access point has a gold, unlocked icon, tap the access point's name, and then "OK." The system will then establish a connection with your router.
    If The access point has a gold, locked icon, the Nintendo DSi has detected WEP/WPA key security on your router:
    1. Tap the Access Point name.
    2. You can either enter your WEP Key, or click "Change Security Settings" to enter a WPA key.
    3. Tap "OK" again and the system will then establish a connection with your router.
    If The access point has a gray, locked icon, the system has determined your router is set to WPA security. You need to access the Advanced Setup area of the system to connect with this security method.
    • Instead of tapping "None" in "Connection 1", click "Advanced Setup", then click "None" in "Connection 5".
    NOTE: All information taken from http://www.nintendo.com/consumer/systems/dsi/en_na/usb/index.jsp
    Oct 09, 2010 | Nintendo DSi Black Console
    Psp internet problem
    Sep 15, 2007 | Sony PlayStation Portable (PSP) Console
    Video Game Consoles & Games Logo
    562 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
