Question about Frigidaire Washing Machines
Front loading ATF6700 goes into "pause" mid cycle every 2-4 minutes during wash and rinse cycles. I can restart cycle by pushing "Pause/Start" a couple times.
  • 2 more comments
  • garyamado Jan 02, 2011
    It pauses "mid cycle" not at the end of the cycle when it would be pumping water out. When I cancel the rinsing and start the washer all over in the spin cycle alone, it pumps water all out, without the stand pipe over flowing, and spins the normal semi dry before stopping at the normal end point.
    Your answer seems to be for another question/problem.
    The pause comes in Mid-cycle not when it is trying to pump water out. There seems to be a hum that precedes the pause. It ran completely through when I reset the washer to the Spin only cycle.
    Are you referring to a lower panel on the back because the front is just one full panel. Also, the Frigidaire Service Manual shows no filter on the drain pump or a drain pump filter cover that I can remove.
    Sorry, neither of the 2 solutions received seemed to pertain to my Frigidaire washing machine. I discovered while investigating further that the cold water valve had been inadvertently turned off and apparently the machine automatically goes into "pause" when wash or rinse turns on when "cold" set and no water enters.
    Do I get a return on my $12?
    President:
  • 1,654 Answers
You are going to have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good to go. If this does not fix the problem then the pressure switch is bad. Try this first and let me know if you need advice on the pressure switch.Thanks for using Fix ya
Posted on Jan 02, 2011
  • Dcramer531
    Dcramer531 Jan 03, 2011
    Absolutly, if a solution to your problem is not given to your satisfaction there is no charge, just make sure you reject the answers given if your not satisfied. I am sorry that I didn't have the correct solution on my first try at this but I am glad your back in business. The problem you described was a common issue with drain pumps and that is why I started there, this is the first I have seen with the water being shut off, I didn't expect that one.
  • 2,382 Answers
Hi, check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit air tight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Jan 01, 2011
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
    Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
    Mar 18, 2015 | Whirlpool Washing Machines
    Motor won't turn on Samsung VRT Plus WF433B*GJ**
    When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
    To add a forgotten item:
    1. Press the Power button.
    2. Press the Start/Pause
    3. Wait for the door lock light to go out (Immediately).
    4. Add the item, close the door, and press the Start/Pause
    The door safety state continues for 15 seconds and the cycle is restarted.
    ensure thorough cleaning,
    To
    Try washing bedding, towels, undergarments,
    contact using the ActivFresh
    GETTING STARTED
    1. Load your washer.
    2. Close the door.
    Z_
    Push the laundry into the drum completely to prevent the laundry from being caught in the door or
    ....... from falling out of the drum.
    3. Press the Power button.
    4. Add detergent and additives to the dispenser (page 20-21).
    5. Select the appropriate cycle and options for the load (page 14-16).
    6. Press the Start/Pause
    7. The Wash Indicator light will illuminate.
    8. The estimated cycle time will appear in the display.
    The time may fluctuate to better indicate the time remaining in the cycle.
    The actual time required for a cycle may differ from the estimated time in the display depending on the
    water pressure, water temperature, detergent, and laundry.
    9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
    quick drain.
    When the cycle is complete, the door lock light will go out and "End" will appear in the display.
    DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
    "Loading your washer" section (page 13).
    When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
    continues.
    Pressing Power button cancels the cycle and stops your washer.
    The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
    Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
    Duet GHW9150P Front Load Washer: I put my machine on pause and now I can't restart....
    Press "end of cycle" for 3 seconds, wait for 2 minutes, try door. Shut door and restart your cycle. If door still does not open - repeat 'end of cycle' press for another 3 seconds.
    May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine does not drain during rinse cycle?
    Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
    If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
    May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
    Washer stops during rinse cycle and isn't easily restartable....
    Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
    Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
    May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washing Machines Logo
    108 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
