Question about Philips 55P8241 55" Rear Projection Television
Philips Projection TV
I have a Philips modle # 60P8341 and the remote stopped working a while back, so I bought another one and that one didn't work so I have been working it manually.  Recently the TV would automatically turn off and I think that the keyboard that contains the on-off button as well as the sensor for the remote (Part # 313501707611) is shot.  Does this sound like a correct statement? NEED NASTA KEY BORB
2 Suggested Answers
SOURCE: Philips Projection TV
i have a philips projection tv. when i turn it on. the tv shuts itself off??
Posted on Oct 05, 2008
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
http://servicemanuals.vstore.ca/
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Remote control
Try installing a pair of new alkaline batteries into the remote. If the problem persists, I would suspect the remote is defective and return it to the store for a refund. I have used Philips remotes twice before, and had problems with both of them. I switched to a One-for-All universal remote, and it has been trouble-free, so far.
Jul 05, 2008 | Philips 60P8341 60" Rear Projection...
60" philips projection tv
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Mar 07, 2008 | Philips 60P8341 60" Rear Projection...
Sorry, I meant what part to replace on the keyboard, not remote. Typo
Oct 20, 2007 | Philips 60P8341 60" Rear Projection...
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Tv turns on and off by itself,volume buttons on controller and panel don't work after while
An all too common problem with that unit is the Ssb or (small signal board, Philips p/n# PH3912725871 located just behind the tuner. It's actually a simple fix for a shop, what we call a plug & play repair but the part isn't so cheap. Last one I did thursday I bought from Vance Baldwin $267.82 plus shipping and core. You get the core back when you return the old part.
You might call a few shops like you know what you're doing and ask what they charge for changing the Ssb in your unit.
Have a great day!
Bill
Sep 02, 2007 | Philips 60P8341 60" Rear Projection...
Tv responds slowly and doesn't hold memory
HI NEED REPLACE A SSB SMALL BOARD IN LEF SIDE
IS VERY FAST TO REPLASE IS HAS ONE WHITE CABLE PLANE INSERT TO BOARD THE SMALL BOARD IS INSERT TO BIG BOARD IS COST YOU $ 319,88 LESS $ 100 CORE BACK A OLD BOARD
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Philips 55P8241 55" Rear Projection Television Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
