SOURCE: Samsung TXN2726 TV Does not turn on
This denotes a power supply problem. The trouble could be in the low voltage or the high voltage supply. You will need a schematic and at least a multimeter to even beging to troubleshoot this problem. If you do not have a background in electronics. I would suggest taking the set to a TV repair shop.
SOURCE: Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
SOURCE: Samsung TSL3293HF HDTV - TV in Stale State-No picture or audio
Did you get it fixed..I am having the EXACT same problem with mine..would love to knoe how much you are spending. Should I junk it? I have had it for 5 years. Kim
SOURCE: Samsung Flat Screen Won't turn On
Replacing the fuse worked for a few days, and then the fuse went out again. I did this 2 times already. The TV repair shop says it might be the "degaussing unit." He may charge me $175 to fix it.
In this bad economy, it may be worth it to fix it than to buy a $1000+ TV.
SOURCE: I have samsung 21 green screen
Either something wrong with the picture tube or something with scart input if you use one. / / David
