Question about GE Microwave Ovens
Our GE built in microwave model # JKP62G suddenly started making a loud noise when we try to use it. It does this on any power level and on the defrost setting also. It does not seem to be heating anything. This is a combination oven and microwave.
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Jan 01, 2011
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
Jan 20, 2010 | GE JVM2070 Microwave Oven
Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Jul 15, 2009 | General Electric Microwave Oven
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Jan 31, 2009 | GE JVM1860 Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
179 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
