Question about Legacy LA838 Car Audio Amplifier
Amplifier my amplifier was working properly until both fuses blew out and i replaced it and it still dont work and its smoking within the inside.
The fuses blew but then smoke came out of my orion 2400.If I replace the fuses should it still work??
If you are a lucky person..maybe.. but i highly doubt it. ..Sorry.. Smoke is never a good sign when it comes from within the amplifier. Be aware i am advising according to the info you provide. Have it checked and repaired if required, it is a good amp. (find an authorized technician) dreamsystems
Feb 08, 2011 | Orion HCCA-D2400 Car Audio Amplifier
The amplifier blew the 35A fuse, i replace the fuse with a 40 fuse and it only works for a moment then the subs cut off. can you help me plzz im in need of bumping.
Dont use a larger fuse. You can damage the amp. Make sure your alternator cables and battery have good connections and plently of current available.
Jan 27, 2011 | MTX JackHammer JH600 Car Audio Amplifier
My cigarette lighter fuse blew, we replaced it and the fuse blew again within a day what do i need to do
try to tighten lighter element to lighter handle, if this does not work replace the lighter assembly
Mar 11, 2010 | 2000 Mitsubishi Galant
My mg100hdfx head shorted out and i replaced the fuse the fan also smoked and sparked when i replaced it and then i put in another and it still dont work what should i do
When the fuse blew you should NOT have replaced it without investigating the cause.
It is likely several components were damaged and probably more when you replaced just the fuse and tried it.
The unit needs to go to a shop now for refurbishment.
Feb 15, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Blew fuse, replaced it,turned it on and fuse blew.... options?
There is something wrong inside that is causing the fuse to blow. The fuse is the first defense in protecting the rest of the TV. The internal voltage regulator could be bad which is causing the internal power adapter to send too much voltage and current to the rest of the tv. The fuse responds to current going through it than what it is rated for.
With that in mind be sure to not stick in a bigger fuse as it could cause the tv to work for a while until something else gets damaged or the tv smokes.
Jan 02, 2010 | Olevia LT32HVM 32 in. LCD Television
ROCKFORD FOSGATE T-3000bd POWER AMPLIFIER
u probley just cooked the amp cant tell u how much and i say that for every body so dont be stupid asking q. and a's like that
Oct 27, 2008 | Car Audio & Video
Legacy LA838 Car Audio Amplifier Logo
50 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
