Question about Culligan Sediment Water Filter
I have culligan 01014042. Can you tell me which way the salt plate goes, legs up or down. thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
The legs of the salt plate go down. Add about 5 gallons of water to the tank after you get it allback together.
RJ
Posted on May 20, 2011
Culligan water softener 01014042
IF you are unsure about working on this ,then maybe you should get Culligan to send out one of there techs . I did phone a tech line for mine they where very help full and we solved the problem over the phone . Try the help line first nothing lost on a phone call .
May 16, 2017 | Water Heaters
My culligan mark 100 soft -minder water softner salt tank overfills
First check the eductor assembly. Top of valve under chrome plate. Pull it out and clean it (after bypassing and depressurizing the system)
If that is OK the the brine piston will need to be replaced. There is a rebuild kit for this series valve that is about $120 that includes the refill piston and a retrofit kit. It would be wise to rebuild the valve.
See your local culligan dealer
RJH2O
Nov 23, 2012 | Culligan Sediment Water Filter Heavy Duty
Culligan medallist softener will not regenerate unless done manually, not sure how to set different locations. 1 set to present time, 2-2:00 am, 3-10, 4-10, 5-10, 6 is set to 71 degrees, 9 is set to U, 10...
How do you know it is not regenerating? When hard water occurs through system it may still be regenerating but not drawing brine or refilling the salt tank properly. First check to see if it is metering the gallons. Run water and check for the flashing icon. If it is not metering the gallons, the meter is bad, dirty (iron buildup) or the board is bad. Clean the eductor assembly on top of valve (under chrome plate) this may be plugged.
Here is a link to the manual for your medallist softener.
http://www.culligan.com/uploadedFiles/Service_and_Maintenance/Customer_Support/Owners_Guides/Water_Softener_Owner_Guides/Culligan%20Medallist%20Series%20Water%20Softeners%20fr%202007%20%28Rev%20B%29%2001020482.pdf
RJ
Aug 14, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Have a water filter by culligan ..a 01014042 ser # 0703k0196 need a user manual
This is a Medallist series water softener. Her is the link to Culligan for your owners manual.
http://www.culliganwater.com/residential/resources/timers_manuals.php
For future reference it is more helpful to provide the Model and the year it was installed.
RJ
Sep 09, 2010 | Culligan Sediment Water Filter
I have had salt in for 3 weeks culligan mark 89 is not recharging
If the unit will recharge then you might have what is called a salt bridge in the tank. The salt is stuck above the water level in the salt tank. Poor a gallon of water over the top of the salt and see if you can then break it up. The salt should go down then.
Dec 01, 2009 | Culligan Sediment Water Filter
My culligan mark 89 water softner the salt bin never is used up anymore. its been 2 months now and its still full but i hear it everynight turn on
Try cleaning the filter screen under the metal cover plate. Also check your water supply pressure. Some softeners won't run properly on low pressure.c8a54da.jpg
Sep 03, 2009 | Culligan Sediment Water Filter Heavy Duty
No salt leaving Culligan softener during regen
I have the same problem... did you find out what was wrong???
Jul 12, 2009 | Culligan Sediment Water Filter
Looking for manual for a Mark 100 Culligan water softner I did the override and they tell me that send sediment into the ejectors. I would like to do this repair myself as I cannot afford a service call...
Hi again Brett, The ejectors they are referring to are the spray nozzles on the bar in the top of the tank. You simply unscrew them and wash them off, don't loose any pieces. The charge is all for labor and know how. Use the link I gave you last time for one of the two manuals and it will show you the pictures of the nozzles. Good Luck to you, this should Fixya!
Mar 24, 2009 | Culligan Sediment Water Filter Heavy Duty
Culligan Sediment Water Filter Logo
229 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
