Question about Festina 6637-5 Wrist Watch for Men
Necesito cambiar la fecha de mi reloj festina 6637
Como cambiar fecha en casio g shock gw3000b
Hola,
Aqui puede encontrar la ficha completa del reloj:
http://www.tictacarea.com/es/relojes-casio/4557-reloj-casio-g-shock-gw-3000b-1aer.html
En este enlace puede descargar el manual :
http://www.tictacarea.com/es/index.php?controller=attachment&id_attachment=5
Si tiene cualquier duda puede consultarnos,
Distribuidores oficiales de Relojes Casio
TictacArea.com
Jun 08, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
Eve mon crois watch 9441-FS instruktionbook
Watch controls (eve mon crois) TL= top left button TR= top right button BL= bottom left button BR= bottom right button TL= toggle light TR= view date BR= view alarm time BL= toggle options 1 press --> stopwatch 2 press --> change alarm time 3 press --> change digital time 4 press --> return to regular view (When on option) Stopwatch: TR= stop/start stopwatch BR= reset stopwatch time BL= next option Change alarm time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Change digital time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Normal view: (controls shown at top) In normal view when: TR is held down --> BR= toggle alarm on/off TL is held down --> BL= toggle through days BR is held down --> TR= toggle alarm on/off (for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second) I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
Jan 30, 2014 | Watches
How to set up the chronograph needle
acabo de adquirir un reloj armani AR0431 segui las instrucciones ajuste fecha y hora, pero no trabaja..que pasa a caso no bienen de fabrica con la bateria instalada? o cual podria ser el problema?
Sep 11, 2012 | Giorgio Armani Emporio Armani AR0584 AA...
Hello1 I would like to know how i can take a how to use ...instruction
For instructions go to http://www.festina.com/ and click on "downloads".
Put your model number in the box and click on "Search".
Jun 28, 2011 | Festina 6637-5 Wrist Watch for Men
Como porfabor puedo descargar o obtener el manual de instrursiones de mi relo Citizen eco driver e310 pero no se cual es el modelo aqui le dejo porfavor alguno de los datos que tiene en la tapa y en la...
HOLA YASSERDIDIE !!!!!!!
ENCONTRE UNA PAGINA DONDE VIENE UN MANUAL PARA EL RELOJ CITIZEN E310, ES UN ARCHIVO EN PDF Y VIENE EN ESPA?OL
EL LINK ES: http://sumanual.com/instrucciones-guia-manual/CITIZEN%20WATCH/E310-_S
ESPERO SEA EL MISMO MODELO QUE TU RELOJ Y QUE MI INFORMACION TE SIRVA PARA RESOLVER TU PROBLEMA. :)
Apr 29, 2011 | Citizen EcoDrive Calibre 3100 BT000007E...
Festina 6637-5 Wrist Watch for Men Logo
378 people viewed this question
Top Festina Watches Experts
Ansel Alberto
Ansel Alberto
240cpa
Are you a Festina Watch Expert? Answer questions, earn points and help others
