Question about GPS
My Guide 3000 GPS System
I own a My Guide 3000 GPS System. It was given to me as a Christmas present in 2007. One day I was playing a game on it, I don't remember which game it was, and I turned it off without exiting out of the game. Then when I turned it back on, the main menu did not appear. Instead, it went straight to the menu that has the options Multimedia and Settings. Now every time I turn it on it goes straight to that menu. I have tried a hard reset. I've tried taking the SM Card out of it. I've tried pushing the Main Menu button. I've tried touching all four corners, but none of them will get you back to the main menu. I've gone to Music, Pictures, and Movies, all of them, and pushed the X which is supposed to take you back to the main menu, but instead it took me back to the same menu with Multimedia and Settings. Everything I've tried has not worked. The navigation part consisting of the Cockpit and Maps area worked just fine until I started playing that game. What do I need to do to fix it in order for it to go back to the Main Menu?
  • 1 more comment
  • alidewar Mar 09, 2009
    i have the same problem but my original memory card works, its a second memory that that i have bought that doesnt work, even though i have put all the same files and folders from the first one onto it. I couldnt realy understand the help that awkrin_23 gave to that last person, when he says "go to windows explorer. when it boots, after u hear the noise, notive a black square appearing" does he mean on windows explorer or on the sat nav coz i cant work out what is meant as neither do what is said to happen
  • Anonymous Apr 21, 2009
    Same problem but this is not primary solution.
  • Anonymous Apr 30, 2009
    I have the same problem where it only shows the multimedia and settings menu. I even just tried messing around with try to push and hold different buttons while turning it on. The furthest I got was being able to attempt to download from the SD until it gave me an error.
It's the same menu but the pna thinks the sd isn't in, so it hides those buttons. u should get to sd card to your computer and look at addons.txt. that contains information about the menus, and if that looks alright(
[modules]
Games = "icons/games.bmp", "", 0
Navigate = "", "\\Flash Disk\\myguide\\myguide.exe"), then u should go to windows explorer. when it boots, after u hear the noise, notice a black square appearing in the left corner, "click" and hold until u see the a menu close to that when u right click your computer's desktop(if it's windows). click new folder and keep touching the desktop for the next ten seconds, so the "main menu" won't appear. then enter the new folder and windows explorer will launch, click the address bar and erase what's there and type \ then press enter. it will go to my computer. go to flash disk (which is the internal rom) and click igo launch. that should launch the navigation software.
Posted on Jul 25, 2008
Need help gettting Plenio to work
Contact Me jeffreydrescher@Bellsouth
I remember w/mine/ the manual commented about a plug option for vehicle
On side of GPS there is a SAFTEY Jack, There should be a Rubber/Metal
Jack-Pin present, w/a new plenio, there was a Hand Brake Safety Cable
incl, that if used (connected to Brake Switch/Other End Plugged Into
GPS SAFETY Port). If Cable Not Being Used, You Should Have The
Black/Rubber/Jack/Port-Pin Installed.
This Might Be Your Problem.
I have the PDF manual, need it, jeffreydrescher@Bellsouth.net
Nov 26, 2011 | Digital Video Systems Plenio VXA-3000 GPS...
We tried to play a region 2 game given to us in England over Christmas. As soon as the game was put in by my nine yr old he answered a question which no one else saw, answering no. Immediately after, the...
Try to RESTORE FILE SYSTEM.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
Unable to save games
if i remember correctly i had two different ds's a original DS and a DSI both of these have automatic game save so your daughter can play a game and just press quit when shes done and it will automatically save it. I hope this helps Merry Christmas!
Dec 22, 2009 | Nintendo DS Console
Which is the software that converts presentations into a self running slide show
there are many different slide show converters,
One of them with a free 30 day trial can be found here:
http://download.cnet.com/PowerPoint-Slide-Show-Converter/3000-2075_4-10385108.html
You need to have PowerPoint installed on your system when using the converter.
Success
Aug 29, 2009 | Microsoft Office PowerPoint 2007 Upgrade:...
Up date my gps my guide 3000 GO
I have the downloaded update files for this GPS and would be willing to trade for a copy of the original SD card. My daughter erased the original card while trying to put MP3 music files on and the update will not load without the original software present. Please contact: ricsgone@comcast.net
Aug 26, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
How to download games on psp3000 v5.01
The psp 3000 cant get cfw but it can get the chickHen mod and here is a very good guide for the psp 3000 to be able to play gameboy advance games and their is only 2 or 3 games u can play atm on the chickhen mod but heres the link http://pspslimhacks.com/guide-to-chickhen-on-your-psp-3000-ta88v3/
Aug 22, 2009 | Sony PlayStation Portable (PSP) Slim...
Lack of instructions for Tevion/ My Guide Sat Nav
I have the manual for the MyGuide 3000GO. Send me your e-mail address so I can give it to you.
Mar 04, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
What is the cd key of cricket07
the cd key is either present on back of your game pack (if the game is genuine) and if you have lost it, then visit to the support site of the game given on the case
Dec 20, 2008 | EA Sports Cricket 07 for Windows
MY GUIDE 3000 GPS Device
Try asking someone else, have you tried updateing the firmware on the gps?
Jul 15, 2008 | GPS
GPS Logo
1,632 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
