Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
I have set up a password for my belkin wireless router and now when i connect it says limited access and the settings saved on this computer for the network do not match the requirements of the network
  • 335 Answers
Hi Andrew,
This should be an easy one to fix. First, unplug power from the modem and the router for 30 seconds. Power on the modem first and wait one minute. Now power on the router and wait one more minute. This will remedy the limited access issue.
Now we'll fix the 'settings don't match' issue. Here's what's probably happening:
You had connected to your wireless network with no password previously and windows saved a connection to this network. Now, you are trying to connect with security enabled and windows is saying "hey, I know this network, but my saved connection doesn't have any security"
So.....you need to delete the existing connection to your wireless network and then re-connect to it.
In windows 7, go to control panel and click on the network and sharing centre. now click on manage wireless networks and delete the connection to your home wireles network.
Now reconnect to your wireless network and you will be asked for the password. Enter it and everything should be good.
Please let me know if this helps. I f not, get back to me and I can help some more.
Regards,
Joe
Posted on Jan 01, 2011
Cant access belkin router w 191.168.2.1 or any combination
. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 27, 2011 | Belkin Wireless (F5D7130) 802.11g/b...
How do I secure my wireless connection?
The exact access and setting procedure can be found at Belkins web site.
Disconnect all cables to the router, then, in essence you connect to the router, usually via direct connection and direct your browser to the address specified (somthing like 192.168.1.1) and log into the router. Things that you want to change are ssytem ID, router name, Router access password (RECORD IT!!!!) and set up wireless security. An easy access password would be your home phone or cell phone number. if you make a cryptic password, tape it to the router, as you will forget it when a guest visits and needs access.
Another setting to check is that your router broadcasts it's presence, usually set to yes, but not always, by default.
SAVE settings on EACH PAGE or they do not save, as you go from page to page changing settings.
Oct 14, 2010 | Belkin Computers & Internet
How to set password for belkin 54g
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings->wep security add password then save settings and restart router then you can connect wireless with that password. . Let me know if you need further assistance. Thanks for using FixYa.
Oct 14, 2010 | Belkin (F5D7633UK4A) Wireless Router
Installation of belkin router failed
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
May 08, 2010 | Belkin (F5D5231-4) Router
What is the pin of belkin G wireless router?
First connect your router to computer with ethernet cable.
Then you can access it with default link.
http://192.168.2.1
Type user as "admin" and password as "admin" or blank or "password" or 1234 then you can se configuration page of router go to wireless settings and enable WEP security add new code so you can connect with that code.
If you want to configure it you can do it with below method.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Save settings and restart router
Then connect internet service provider cable to router .Then you can use it wireless.
Mar 30, 2010 | Belkin (F5D7230-4) Router (587009)
How do i get full access to my g router's wifi signal it keeps telling me i have limited access
http://192.168.0.1
or
http://192.168.1.1
For belkin routers http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings .Change wireless chnnel type to 3 or 6 or 11 Then save settings and restart router.
Feb 25, 2010 | Belkin F5D7234-4 Router
MY BELKIN ROUTER IS ASKING ME FOR A PASSWORD I DON'T HAVE. I NEVER SET A PASSWORD, THAT'S WHY I CAN'T FIGURE IT OUT
You can secure your wireless network wit WEP or WAP code.
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Jan 31, 2010 | Belkin (F6D3230-4) Router (F6D32304)
Hi, i just cant get online wireless, i have to pass my belkin and plug straight into my laptop.
You need to configure the Belkin wireless settings and the configure the wireless card in the laptop with the router's wireless settings.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 13, 2009 | Belkin (F5D7230-4) Router (587009)
How to i set up a password on a belkin mimo router
Not only do you need to change the default password, you also need to secure the wireless from unauthorized access.
Nov 07, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Modem Router not connecting to desktop
The wireless security on your router might be enabled.
1. In the address bar of your Internet browser, type "192.168.2.1". Then press the "Enter" key.
2. It will prompt for a password to access the Router’s Web-Based Advanced User Interface. By default the password is blank.
3. Go to Security, then Wireless.
- Check the wireless security settings, this should match the settings on your wireless computer.
4. On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Jan 14, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
147 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
