2007 Ford Fusion I4 SEL Sedan Logo
A
Anonymous Posted on Jan 01, 2011
Have had no major problems until now - New Years Day. Tried to start auto. When turning key in ignition, all lights on dashboard clicked on and off repeatedly. However, motor would not turn over. Yesterday - noticed that the "front airbag" light on dash remained on for a short period of time - but the light went off when motor was restarted.
Dan Doherty
Level 3:
Genius:
  • Master 1,099 Answers
  • Posted on Jan 01, 2011
Dan Doherty
Master
Level 3:
Genius:
Answers
1099
Questions
Helped
387136
Points
3389
Hi
Sounds like the battery is failing or you have a bad earth from the battery to the car body, the black wire. I would check them first before going any further.
Regards
Dan
p.s try and disconnect the battery for 10 minutes then reconnect this sometimes works, resets the cars computer.
I've had my 2003 Saturn vue for a couple years now and it's been a great car and gave me no issues, until recently. So the 1sr issue was the key getting stuck and I'd have to wiggle it to get it to click...
First off, you need to get a can of electrical cleaner/ lubricant. Disconnect the battery and then spray some of the electrical cleaner into ignition switch. Put a towel on carpet to catch any liquid that makes its way down the steering column. Most of the time this will be very dirty and will stain carpet. Spray some more and this time insert key and turn it to start position, let it return to run position and then off several times while spraying electrical cleaner into switch around key. Inside the ignition switch are these little floating pins that make contact to supply power to relays that open to give strong power to lights, starter, ect. After several years of use, they will build up corrosion, oil residue from grease used inside switch when it was new, and or dust build up. These all cause the pins to stick and also gum up the ignition cylinder that turns when you turn the key. When the pins stick, it continues to supply power to different components such as computer, horn, light relays, ect. Wal Mart and most auto parts stores sell this cleaner. Do not use WD-40 as it is a conductor and will attract dust and short allowing the power to still be supplied even when key is removed.You can also buy a powdered graphite that comes in a small bottle with a tip on it. You can squeeze some of this into the ignition slot to lubricate all the little contacts inside the ignition switch as well as the ignition tumbler...
What does a car with a lock light mean
Chevrolet Malibu Questions - SECURITY SYSTEM LIGHT ...
www.cargurus.com > Questions > Chevrolet > Malibu
CarGurusFeb 3, 2014 - SECURITY SYSTEM LIGHT COMES ON - CAR TURNS OVER WON[T START ... Insert the ignition key into the driver door lock. ... When I start my car 3 keys programmed pops up on my dashboard what does that mean.
Chevrolet Malibu Questions - Why does the anti theft system ...
CarGurusFeb 23, 2011 - Why does the anti theft system keep tripping on my 03 malibu - Every other day my anti-theft system goes off in my car then I have to reset it. It's not ha... ...it needs a pass lock sensor/ ignition lock cylinder. 10 out of 10 people think ... Wait 10 minutes until the light stops flashing, then start. Repairs could run ...
No Start Due to Failed Passlock Sensor : Chevrolet Malibu ...
repairpal.com > Problems > Chevrolet > Malibu
My car started out by stalling when I put the right turn signal on but would start back up. Now it died and will not start back up has new battery. the dash lights come on but when you turn the key
Sounds like you might have wire problem.
Try turning the key to the point before ignition. This is actually a dashboard test that have all lights on the dashboard turn on. Try to see if the lights are completely bright or a bit dull in the light.
You battery might be uncharging itself, instead of charging. I have tried that. even with an only 1-2 day old battery.
This is about to be rather lengthy, so I apologize in advance. I traded for a 98 Firebird on April 19th. Already broke down. The problem doesn't lie within the engine or transmission however. What...
Sounds like the electrical part of the ignition switch, not the lock cylinder that needs replacing.
Possible also that cutting that wire to the security module immobilized it.
2001 nissan pathfinder. seems electronic. first seemed dead battery, put in new battery. fine for couple of days. then dashboard warning signals, oil, battery, brakes, and airbag, start going on. then...
Have your alternator checked. Most auto supply places do this at no charge. Multiple dashboard warning lights usually indicate alternator problems.
1helpful
93 Saturn wont start, battery,lights,all good
There's a relay that's under the dash. keep turning the key until you find what's clicking then replace that relay, the car should start.
1helpful
Turn the key but nothing happens all electrics
Not all replacement parts are good. I would guess that the new ignition switch is bad. Its also possible that the wiring harness is loose where its connected to the ignition switch. You could try jiggling the wires.
1998 Celica engine won't start, rapid clicking audible
sounds like you are on the right track, the battery you have in it has done well to last that long but it sounds like a fell cells have decided to call it quits
2answers
My 2001 Olds Integre will not start, but later does start.
This may be a problem with the ignition switch. The ignition switch feeds power to many of the different systems- including the starting system and the dash.A low voltage output of the switch will not allow the starter relay to engergize, along with many other odd problems. A way to check this is that when it is acting up, turn the ignition key back and forth very quickly many several times, or tap and the head of the key with a small hammer. These things will normally cause a faulty ign switch to correct itself for the time being.
http://www.greatautohelp.com/more_oldsmobile_questions.html
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
