SOURCE: how to attach venturi clips
Hi Angie1457...
Look for a hole the size of the venturi clip and insert it into the hole, some are held in place by a screw in the middle of the venturi clip and some have tabs that need to be bent over to have them stay in place.
Please take time to rate me
SOURCE: Regulator Assembly / Venturi tube
YOU'LL NEED TO GET A WRENCH R PLIERS ONTO THE PART THAT IS TURNING SO YOU CAN TIGHTEN IT UP, DON'T FORGET TO USE SILICON TAPE ON THE THREADS OR IT WILL LEAK. THE HOLE IS TO ADD AIR TO THE MIX.
SOURCE: How do you remove the
The venturi tubes are part of the burner. It"s a slot on both sides of the burner tube, where it goes over the burner orifice. You will need to remove the burners to check and clean them.
Hope this helped answer your question.
A venturi is used in many skimmers to draw air into the water flow. As water is pumped through the venturi, air is drawn into the passing water through a small inlet tube. There are many version of venturi in the outlet tube because many brands use modified version of their own.
