Question about Garden
What fuel mix for homelite ZR series Z830sb? - Garden
40:1 for chain saws.
Mixing instructions shown on back of 2-cycle oil container.
Posted on Jan 02, 2011
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
I was given 2 weed eaters, the z830sb, and the d630cd. I need to know what the gas and oil mixtures are for these units.. Thanks Jim
32:1 should be a good mixture for the homelite weed eaters. here is a thread on it, hope it helped Tim:
ttp://forums2.gardenweb.com/forums/load/tools/msg1011591014681.html?13
Apr 24, 2011 | Homelite Mighty Lite Lawn Trimmer
Need to know the fuel and oil mix on a homelite 330 chainsaw
The fuel, oil mix for homelite chinsaws is 32:1. Hope this helps.
Sep 26, 2010 | Homelite ZR10926 16" Chain Saw
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Homelite ZR10926 16 Chain Saw
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
How to remove clutch on model z830sb
The clutch interior must be turned the same direction as the engine to loosen (reverse threads), tapping with a screwdriver and hammer usually does the trick. When you install the new clutch make sure you apply an anti seizing compound to the threads.
May 26, 2009 | Homelite Garden
I am trying to find a parts list layout for a z830sb homelite. I purchased a replacement head but there seems to be an adapter missing at the base of the angle head.
Here is a web site with the diagram for you. you need to first go to this site: www.jackssmallengines.com. then, click on the parts database link near the top of the page. it will come up to a new screen where you have to click on another button to get into the parts diagrams part. from the drop-down menu, select Homelite Consumer products, then click the model number tab at the top of the page. type in "Z830SB" and hit enter and it should bring up a menu for you to choose which diagram you need to look at. Hope this helps. Let me know if you need any more help. I would just give you the exact site, but it will not load up if you don't go through the steps. thanks.
Apr 05, 2009 | Homelite Garden
Homelite zr series z25mhv/160mph fuel line and gas tank parts the fuel line dicinigrated where the fuel filter hooks to
Take a piece of your old hose to your local hardware store and compare the ID of PVC tubing, this should work fine
Mar 24, 2009 | Garden
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
