Question about Canon NP 6551 Black and White Copier
Please help I am getting a error e401 on a canon np6551 what can i do to fix the problem. thanks cavin.   cavinrussell@mac.com
    New Friend:
  • 8 Answers
E401 RDF Pickup motor or pickup sensor problem, try to clean the sensor and reset the error code in *4* ERROR clear.
Posted on Jul 10, 2008
I need to know how about error 203 for canon np6551
E203 means thecopier isnt seeing the scan carriage moving into its home position when you power up
Nov 30, 2010 | Canon NP 6551 Black and White Copier
How do I replace the main top print roll on a NP6551 copier?
It is to hard to explain in typing so if you could call me in the morning say around 8am PST I will talk you through how to get the upper fixing assembly apart. If you need this tonight 6/13/10 go ahead and call me…. I am in San Diego.
Thanks and I will do what I can to help you.
Chris
Jun 14, 2010 | Canon NP 6551 Black and White Copier
Error e20en la canon NP6551
toner is blank, or the box toner is jam.
Apr 30, 2010 | Canon NP 6551 Black and White Copier
I have a canon np6560 and np6551...the 6560 shutdown in the middle of a job...and now only turns on when the door is open, but once i close the door, the on switch kicks off...when the door is closed the...
try to turn on the copier and do not loss the switch I mean still press it
are the copier appier any error or still work
if yes
replace the on/off switch
if no
what the error shown in the control panal
Apr 08, 2010 | Office Equipment & Supplies
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Error Code: E631 & E632 on Canon NP6551
make sure the error code you gave to us is E631 & E632 notE531 & E532, you number not on our menu, if my number is correct that's mean stapler motor defect, replace it!
Oct 03, 2008 | Canon NP 6551 Black and White Copier
Error code: E002 at canon NP6551
canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
Jun 02, 2008 | Canon NP 6551 Black and White Copier
E210
Error 210 means that the printer scanner hasn't returned in its initial position.
You should see there http://en.allexperts.com/q/Repairing-Copiers-Faxes-1748/Danka-Copier-Canon-NP6551.htm , it may help you.
Feb 05, 2008 | Canon NP 6551 Black and White Copier
Error - E401
e401 on a 6545 is the RDF (reversing doc feeder) pick up motor or pick up sensor problem. Does the rdf attempt to pick up the original or do you get the error as soon as you press start? Are you aware of how to remove all the rdf covers? The pick up motor has a timing wheel & sensor that need to be periodically cleaned.
Jan 22, 2007 | Canon NP 6545 Copier
Canon NP 6551 Black and White Copier Logo
96 people viewed this question
old marine
old marine
