Question about HP Pavilion dv9720us Notebook
I WANT TO ADD A SECOND HARD DRIVE WHAT WOULD BE THE PART NUMBER FOR THE CADDY.. AND ALSO UP TO WHAT SIZE HARD DRIVE CAN I ADD
    Sergeant:
    Novelist:
  • 179 Answers
The only practical way to add a second hard drive to the dv9720us is to use an external USB unit. There is no provision for a second internal hard drive (standard for laptops). The "expansion port" is simply another wire connection to the motherboard's data bus, and requires a proprietary cable from HP. Using a USB external drive is a standard approach and does not require any special drivers, etc.
There are a number of good external hard drives w/USB connection available from Costco, WalMart, KMart, and other retailers. HP prefers Western Digital (as do I, from years of repair experience...they last longer), but there are a number of decent brands. You can use any size you want. 1TB drives are not uncommon today. Prices generally range from a little under $100 to around $200 for large capacity drives.
Hope that's helpful.
Posted on Jan 01, 2011
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
I need to replace the hard drive in my Toshiba Satellite M305D-S4830. What size should I replace with (the one it had was big enough). Step by step instructions?
its up to you what size you want to replace it with go onto the toshiba site and there you should be able to get a manual showing you how to do it
Feb 20, 2011 | Toshiba Satellite M305D-S4830 Notebook
How do I size my hard drive mine is 4"wideX53/4 longX1" deep 40gb im looking for a caddy for it
This is almost definatly an E-IDE (PATA) desktop hard drive.
These drives are refered to as 3.5 inch drives, and laptop drives as 2.5 inch.
Just google ide caddy or enclosure
Sep 23, 2010 | Computers & Internet
What do i need to install a WD Scorpio Blue 500Gb hard drive in my HP dv90052us laptop - i've got the drive but it does not fit in it's slot like the original drive does - i'm putting it in the second...
You may need a "caddy" -- a metal shell that wraps around the disk-drive, in order to line-up its "data" and "power" connectors with the matching "sockets" inside the second drive-bay.
Order the caddy from http://support.hp.com
Apr 18, 2010 | HP Pavilion dv9005us Notebook
No caddy for hdd hp pav ze4540
goto ebay.com and find the hdd caddy online .. order the full kit to install a drive or second hard drive
Sep 28, 2009 | HP Pavilion ze4540 PC Notebook
Use second hard drive
The Windows operaring system is on your 1st drive (ie C drive) and if you change it to a slave drive the computer won't work.
You need to set the jumper on the 2nd hard drive as a slave drive and leave the original drive as the master drive expecially if the 2nd drive is on the same IDE controller and cable as the 1st. hard drive.
It doesn't matter if the 2nd drive is set to master or slave if it is on the 2nd controller.
When you boot up you should see both hard drives and can copy files from one drive to another.
Apr 08, 2009 | IBM ThinkPad R40 2681
Hi, i buy used laptop L355D-S7815 without hard disk i put a new 1 work fine but i don`t know if must have a caddy or something else because feel like is loose please help. thanks.
Some laptops need a caddy, but if the hard drive can fit in without a caddy then don't worry about it. If the drive is a bit loose then wrap or add some paper around the hard drive to stop it moving about.
Apr 02, 2009 | Computers & Internet
Hard drive
Doubleclik on "my computer" and rightclick on your harddrive and select "properties" from the menu, it will show you usage and size of your harddisk.
Aug 11, 2008 | Compaq Armada E500 Notebook
Hard drive connector
It is called Hard Drive Caddy connector or Hard drive bracket , part number 465170802.
Ensure that you do not need the whole caddy.
Here is a reseller find more by putting part number in google.
regards
Mar 23, 2008 | Sony VAIO F540 Notebook
HP Pavilion dv9720us Notebook Logo
150 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
