Question about Refrigerators
Admiral fridge side by side model HMG65158 Fresh food side not cold enough
My understanding is that whirlpool took over Admiral and May Tag and I can't find help from either one.
I need help with my side by side fridge.
The freezer side works well and produces ice, no problem here.
The fresh food side the temperature barley reaches 56ยบ and it is not cooling well enough.
I have cleaned the coils and re set the thermostat for the fresh food sides and I only gain a bit more of cooling, I can here the motor and the click of the thermostat when I advance or ****** the cooling knob.
The all around door seals are in good shape and I don't detect any loss of cold temperature around the doors.
Is there any other thing that I my try and see if I can get a better cooling setting?
I'll appreciate very much any help on this matter.
Thanks Ed
mikedurland
  • 481 Answers
SOURCE: kg34na90gb fridge freezer - fridge
turn the freezer up to highest setting and set the refrigerator control to about half way. this will block some of the airflow into the refrigerator.
Posted on Jul 06, 2008
SOURCE: ADMIRAL SIDE BY SIDE COILS FREEZING UP
sounds like a defrost problem. most of the time it's the heaters behind the coils.
Posted on Aug 13, 2008
SOURCE: How do I replace Fan moter of Admiral Refgirator model LSD2615HEZ?
Lower freezer setting so more air can travel to refrig
Posted on Sep 16, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
  • 118 Answers
SOURCE: admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Posted on Jan 31, 2009
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
How much program 134a receives the admiral gc2224gekb
The weight is posted on the model number tag inside the fresh food section.
Probably 6 ounces.
Jun 26, 2011 | Admiral 26 cu. ft. Side-By-Side...
My Admiral HMG241777 is not cold, freezer is okay.
Most reasons for fresh food section not cold but freezer ok is a defrost problem or evaporator fan not functioning. Look at the back of the freezer, if it is covered by frost it is not defrosting and will not circulate air properly.
Jun 22, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral fridge, freezer won't stay cold
Jan 31, 2009 | Maytag Admiral Top-Freezer Refrigerator
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
204 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
