Question about Cuisinart CJK-17BCFR Electric Kettle
My Cusinart CPK17 kettle does not work on the blue light keeps flashing. It will neither heat nor switch off.
5 Suggested Answers
SOURCE: How do I clean the contact points between kettle and platform?
I had the same problem before mine broke completely (see my problem posted today). The problem seems to be the support that holds the center pin inside the control. I have not been able to fix mine. Now it is totally broken and Cusinart has been no help. How old is your unit? Cuisinart told me that there is a 3 year warranty. Give them a call. They can decide based on the serial number whether they will cover it.
Posted on Jan 04, 2007
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Posted on Mar 11, 2009
SOURCE: the kettle lights up but won't heat up
Too funny, but I solved the problem by returning the Kettle, all
the correct lights came on but it would not boil....so purchased a
different one.
J.
Posted on Apr 13, 2010
  • 9 Answers
SOURCE: When the kettle is switched on, the light comes on...
sounds like the element has died. If it's still under warranty, take it back. If it's not under warranty, contact an electrician or appliance repair person. Unless it's an expensive kettle though, it's probably not worthwhile fixing, as elements can sometimes be as expensive as a new kettle
Posted on May 23, 2010
My kettle is all other sudden not heating up water
Sounds like the heating element has burned out or is shorted, they don't repair this type of appliance they just replace it.
Oct 14, 2016 | Cuisinart CPK17 Electric Kettle
Kettle won't heat
probably burnt out the heating element .mostly a throwaway item
Aug 19, 2016 | Cuisinart CPK17 Electric Kettle
Cuisinart PerFecTemp Cordless Kettle
You can't, there is no adjustment provided for.
Jul 16, 2016 | Cuisinart CPK17 Electric Kettle
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Heating
Mine had the same problem. It ended up being the black box relay on the circuit board. I cut it open and it was rusted / corroded inside. It would click but it would not send any current to the heating coil. Not sure if you can get replacement parts from Cuisinart.
Dec 01, 2013 | Cuisinart CPK17 Electric Kettle
I have a Cuisinart CPK17 won't heat water and all the blue lights are flashing
I had the same issue with all lights blinking, but nothing else working (buttons would not respond or beep). I took the base off and used a small pair of pliers to bend the contact as Scott Cowen mentioned. Worked like a charm.
Jan 07, 2013 | Cuisinart CPK17 Electric Kettle
I brought a CPK-17 Perfect Temp Kettle abouut 10 months ago. It was purchased because I liked the features and trusted the Cuisinart brand. The kettle which was used once or twice per day, stopped working...
you have an high end kettle that will fail the temp sensor certainly has that's why it only stays on for a few seconds to a minuet, they are not made so they can be repaired.permanent bonded thermostats. micro processor etc all none repairable, any water getting to any part on this brand will make it not work correctly..
Oct 18, 2012 | Cuisinart CPK17 Electric Kettle
Cuisinart CJK-17BCFR Electric Kettle Logo
2,855 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
