I have the dimplex heater model nnf5500. The heater does not work. The fire place light comes on only. The heater and fan does not. What can I do to fix this problem.
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Posted on Jan 21, 2009
SOURCE: motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Posted on May 19, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Have a Dayton Model 3e228D heater. Problem, unit
The fan switch on this unit is a bi-metal switch located on the heat exchanger. Check for a bad connection. It is 120 volts so be careful when checking. you can test the switch with an volt meter or one of those probe lights to see if the switch closes when hot. you are looking for 120 volts to the blower motor. Spin the blower motor to see if that is bound up with debris.
Posted on Dec 01, 2009
  • 415 Answers
SOURCE: Dimplex Electric Heater Model Number DF 3003 fan
Dimplex has a Service Manual for your Heater. I recommend requesting the manual through their Literature Request website. I located the owner's manual and the troubleshooting guide via their website, but it appears you will need to request the Service Manual.
Hope this helps.
Posted on Mar 30, 2010
SOURCE: does dimplex model 6902340100 have a fuse, stopped
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Posted on Oct 21, 2010
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Nov 28, 2012 | Dimplex DS4411 Electric Heater
It screams when fired up
It sounds like either the rod that holds the bulbs and turns to produce the flame effect may have gotten out of place or need cleaning and lubricating with light oil. If you're using the heater and fan, the fan motor and shaft may be causing the problem. In which case, they would need cleaning & lubricating too.
Hopefully, you still have your Owners Manual, because that will show and tell you how to access all these parts that are under the simulated firebox.
Feb 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My dimplex fire place heater makes constant clicking noice, can you please help?
this is probably the spark igniter the button you push to light might be stuck
Jan 12, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Dimplex Electric Heater Model Number DF 3003 fan motor not working. How do I access the fan motor to repair or replace it?
Hope this helps.
Mar 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Fire place insert light replacementht
Dimplex has discontinued use of the remotecontrol unit you have requested; therefore we are no longer able to providethis as a replacement part. In order to operate your unit please plugyour power cord directly into your wall outlet and operate the stove via themanual switches.
Aug 20, 2009 | Dimplex Compact Electric Flame Stove...
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
