Question about GE Hotpoint Over-the-Range Microwave
Hotpoint overrange microwave, all the lights and timers work not heating food. there is also a smell when trying to heat is this a common problem with this microwave?
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Jan 01, 2011
My microwave wont heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Goldstar MV-1501 Microwave Oven
Frigidaire microwave electricity works because the lights and timers work but the microwave does not heat. need assistance
There are few parts that will cause this problem, the power diode, defective high voltage capacitor, or the magnetron that heats food is a common failure, and the least likely is the high voltage transformer that drives the magnetron. Parts and labor will run high depending on what needs to be done, I suggest appliance repairman to see it it can be repaired at a reasonable price.
Jan 25, 2011 | Frigidaire Microwave Ovens
The microwave no longer heats food and it smells as if something is burning. Everything else on the microwave works. Is this a common problem and how can I fix it?
Its your Magnatron tube, thats what makes the microwaves and heats the food. The part will cost you more than a new micro. The new model that replaced yours is a JVM1540 and you can get them for 179.00
Jan 17, 2011 | GE JVM1440 Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns, gives out strong burnt plastic smell, little (or no) heating
I would first suggest that you look inside the cooking cavity to see if your wavegudie cover is burned or carbonized. If so, it will need to be replaced. You can order one via Tritronics at http://www.wehaveparts.com The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Once you remove and / or clean the cover and clean the opening of the waveguide, if it still won't heat and/or still has the smell, you may have a bad magnetron or high-voltage transformer. Feel free to post back if you still have trouble.
Dec 05, 2006 | Sharp R-1610 Microwave Oven
GE Hotpoint Over-the-Range Microwave Logo
93 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
