Question about Garland H283 Gas Kitchen Range
We have a Gaffers & Sattler counter top stove, Pilotless/gas-saver ignition. After cleaning - all burners work wel and the ingnition is working well (fast clicking sound as it starts the flame). Problem the clicking ignition sound is slow an will not turn off) Any help - Please
  • sharla1w Jan 02, 2011
    Thank you, the clicking started slowing down about two hours later , kept slowing untill it came to a stop.
    We will unplug if it starts back again. Thank you once more, we were concerned.
    President:
  • 2,047 Answers
Ignition problems are always caused by electrical issues. The igniter is always powered by the the electrical current which flows into the unit. Most units after cleaning either by self clean cycles or manual cleaning most often come up with ignition problems. All you need is an expert to help you take a look at the unit and most likely clean the ignition lines this will stop the malfunction. Although if the continuous sound of the ignition worries you after the unit comes on you can simply unplug the unit from its power source and the continuous clicking will stop. You can use this method pending when you get an expert to fix the unit.
Hope this solution has been helpful?
Posted on Jan 01, 2011
  • Rockme
    Rockme Jan 02, 2011
    Thank you for the feedback. Do please keep me posted if any occurence comes up.
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Igniter knobs on my gas stove turn just enough to let gas escape.
There isn't much you can do to the stove outside of buying a stove that has standing pilots or shutting off the gas each time you leave the kitchen. This is a problem with the pilotless design. If the knob isn't turned far enough the activate the spark switch, gas can escape without being lit. Vigilance is your only answer outside of the solutions suggested.
Apr 28, 2013 | Kitchen Ranges
Gaffers & Sattler stovetop model 1465/944. The burner mechanism malfunctioned when we turned the knob where it connects to the burner and is leaking gas and will not turn off. We would like to find...
Not that many parts for a 33 year old appliance are still avaiable but try one of these places
http://www.antiqueappliances.com/
http://ths.gardenweb.com/forums/load/antiques/msg0717405813237.html
http://www.facebook.com/pages/Vintage-appliance-restoration/124642017603277
http://www.stovelady.com/
I have been a appliance tech for 30 years and love the vintage appliances and strive to search for to repair them whenever possible if the customer wants to hold on to them
Good luck,
Gene
Aug 05, 2011 | Cooktops
Stove-top burner grate is broken
I THINK NO AVAILABLE FOR REPLACE COZ IS FACEOUT MODEL AFTER 10YRS.ALSO U CANNOT REPAIR COZ EVERY TINE U USE WILL BROKEN AGAIN.
May 26, 2009 | Cooktops
Can't find the oven pilot on an old Gaffers and Sattler "Energy Saver Range with Uni Burners"
With the help from your site I was able to hold a match under the bar under the oven shelf toward the back and light the pilot. I am SO grateful. I hadn't been able to see it but just held a match toward the back, and it lit.
Feb 27, 2009 | Garland H283 Gas Kitchen Range
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Garland H283 Gas Kitchen Range Logo
147 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
joneable
Level 1 Expert
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
