Question about Samsung WF337AA Front Load Washer
Front loader grinding noise when spinning - Samsung WF337AA Front Load Washer
2 Suggested Answers
tkamidget
  • 7 Answers
SOURCE: Samsung front loader washing machine making noise
IF IT IS VERY LOUD SOUNDS LIKE IT NEEDS BEARINGS REPLACED
Posted on Jun 17, 2012
Defy Laundromaid 1300 making grinding noise while washing,how do i remove pulsator to see if there is something in it
if the grinding noise is more pronounced at spin cycle , it could be the drum it self, if the grinding noise is there constantly, could be the bearing to the drum. front loader. easy to fix, let me know..
Apr 14, 2014 | Washing Machines
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
Whirlpool washer dryer has been making a grinding noise for a while and now won't drain
Hi.
The grinding noise was probably being caused by objects stuck in the drain filter. Disconnect power and check the drain filter. On Whirlpool front loaders the filter is accessed from the front of the machine. You will need to unscrew the filter cap and to remove blockage With top loaders the access is underneath or at the back. You lean the appliance on one side and disconnect the hose directly connected to the pump. Disconnect power before starting maintenance.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 10, 2011 | Washing Machines
Won't spin--just makes a grinding noise
Hi.
The grinding noise usually means that there are objects stuck in the drain pump filter.
with front loader the drain pump filter is often located behind an access door or a trim on the front side at the bottom. Open the door or remove the trim, then unscrew the cap. Be prepared to collect the water. Disconnect power before starting.
Top loaders have pump access from underneath or at the back.
Apr 26, 2011 | Washing Machines
Wont agitate or spin tryied putting on drain spin setting pump will run and run but wont spin
Top loader washers the main reason is either the motor coupling has failed. You will hear a grinding or growling or whirring noise or the lid switch has failed. The lid switchy will keep it from spinning but usually it will agitate. Check and make sure the drum is not froze and won't move, if it is free, check the coupling under the tub and make sure the motor and tranny are connected. If they are then the transmission may have failed. If this is a front loader the main reasons are a bad motor.
Mar 31, 2011 | Washing Machines
Loud grinding noise when on when it starts to spin?
If it is a front loader, then it sounds like the drum bearings have failed, spin the drum from the front by hand, if it feels rough or is noisy, then bearings have failed.
Jan 26, 2011 | Washing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Kenmore 90top loader,wont spin or pumpwater all out just makes a loud grinding noise,,
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 18, 2010 | Kenmore 24032\24036 Top Load Washer
Samsung WF337AA Front Load Washer Logo
24 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
