Question about Bulova Watch
Instructions for precision w0024 - Bulova Watch
Seiko precision tp-20 timekeeper manual
This link will give you the instruction book.
http://www.bundyclocks.com.au/manuals/seiko_tp20_um.pdf
Glad I could help.
Dec 07, 2011 | Watches
Hi i have just now received a new watch and i want to know how to set analog time. thanks, Abhishek
Hello.
To give a more precise instruction, I would need to know the watch model. But the standard procedure to set analog time would be to pull that little pin on the side of the watch, and than turn it. You should see the handles turn accordingly. Notice that the pin may have two different "heights", one for adjusting time, and one for adjusting the date.
Let me know if that solved it!
Mar 01, 2011 | Watches
Hi my navy seal is in great shape however sometimes it runs fast sometimes slow and sometimes stops is this common? can it be repaired? or does it need a movement swap? any and all comments...
It sounds like the quartz crystal may be the problem, it must vibrate at a precise frequency which is critical in controlling the exact speed and thus translate into precision time. I would get the watch checked to if it can be fixed at a reasonable price.
Dec 23, 2010 | Navy Seal Luminox Dive Watch
How do i get my watch to not beep on the hour
Press the mode button until you come the alarm setting mode(s) and turn the hourly alarm off by pressing one of the other buttons.
You may have to experiment on which is the alarm setting you want as the alarm name is likely to be abbreviated.
Have patience and keep trying!
Since I don't know the make of your watch I cannot give you any more precise guidance than this.
If you have no luck in sorting it out, tell me what make of is your watch and I will try to find the user instructions
Mar 12, 2010 | Watches
New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
Jan 24, 2010 | Timex 27191 Wristwatch
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
How to set time Casio W-89H two button watch
Actually, the watch has 3 buttons -- "Light" being the 3rd one. Press Mode until a number in the time mode begins flashing. Then press the Light button to get it to the hour indicator. Use the 12-24 Hr button to set it to the current hour. Then press the Light button again to get it to the minutes section. Again, use the 12-24 Hr. Button to set it to the next minute coming up in the current time. Then push the Light button again. This will bring up the seconds indicator. At the precise time the minute you set before begins, hit the 12-24 Hr. button, and the indicator goes back to zero and begins ticing away. Then hit the Mode button again until the watch is in the current time mode. Hope this helps. I use Internet time to set a precise time.
Jul 17, 2009 | Casio Watches
How a chronograph watch works?
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Jan 10, 2009 | Sector 2653940025 Wrist Watch
Greetings:I received a Timex Perpetual Calendar wrist watch for Christmas. No box, no instructions for setting the day and date. I simply cannot get these parameters to coordinate. Obviously the new...
http://www.timex.com/gp/node/n/255235011/178-1795200-7359408?ie=UTF8&timexBrand=core
This link will take you to the official Timex page where you can download the instruction manuals for any of their watches.
Dec 31, 2008 | Watches
How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Dec 31, 2007 | Watches
Bulova Watch Logo
35 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
