SOURCE: Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
SOURCE: I have an over the
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door
switch or mount trouble is usually caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One
test that sometimes helps is to gently lift up (and/or push down) on the
door or handle as you try to start it. If it works or tries to work,
then it's a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here onFixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
SOURCE: GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find
model number here.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
We're
SOURCE: ge profile microwave oven runs when door is open
Good way to cook yourself! It has to be a stuck door interlock switch--the case needs to be removed to get at the switch. It could be either the mechanism that operates the switch or the switch itself is bad. The switch normally makes a click when the button is pressed. Unplug the unit when the case is removed.
SOURCE: Humming ge sapcesaver microwave
During operation, most of the built-in models have a panel that tilts out while the exhaust fan is on. When cooking is done, the exhaust fan shuts off and the panel retracts to its normal position. With the fan & microwave motor off, the hum is easier to hear. Look closely at the top panel the next time you hear the hum, and you'll probably see that it's retracting.
