Question about Microwave Ovens
Manual for Pyrex digital probe oven thermometer
Can I freeze a cooked apple pie in a Pyrex dish
Yes Pyrex should be tempered so, it will not hurt pan
Sep 06, 2017 | In Microwave Ovens
I am cooking a roast beef dinner for Christmas I bought a 13lb chuck boneless and I need to know how long to cook in in a traditional oven.
5 After browning the roast at a 500°F temperature in the oven for 15 minutes, reduce the oven temperature to 325°F. To figure out the total cooking time, allow about 11-12 minutes per pound for rare and 13-15 minutes per pound for medium rare.
Really, you need a probe thermometer. Leave it to rest for 15 minutes after you take it out of the oven, loosely tented with foil. I am a chef!
how long to cook Google Search
Dec 24, 2016 | In Microwave Ovens
Instructions for reheating
same as for cooking. Get yourself a probe thermometer. Reheat on full power until the internal temperature is 165'F. Don't use the microwave with the thermometer in the microwave!
Aug 12, 2015 | Microwave Ovens
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
What wattage is toshiba er6860w microwave?
You can do an exact power measurement by putting exactly
500 ml of water in a glass (Pyrex) or plastic measuring cup in the microwave. Measure the beginning temperature and record it, preferably with a digital thermometer. Run the unit on high for exactly 18 seconds. Use a digital watch or a stop watch, not the timer on the unit. Remove the measuring cup and stir the water to make sure that all the water is a uniform temperature. Record the temperature rise. Say the temp rise is 20 degrees Fahrenheit Multiply that figure by 38.75, this would indicate that the power delivered into the cavity is 775 watts. This is the old standard of measuring the power. The new standard called the IEC 705 would add 10% to that for a total of 852.5 watts. This matters more than the rating of the unit because if the power output is more than 15% below the units rated power, the magnetron is probably getting weak and needs to be replaced. Probably not worth the cost to repair. The voltage at the wall could also cause a low power output output. 'Google' the model # to see if you can find any info on this model #......
Nov 04, 2013 | Microwave Ovens
Digital temperture gauge where should readings range and how much varation should occur when door is opened ( cause and effect)
You cannot place a digital thermometer or even probe into a microwave oven cavity that is switched on and cooking, without danger and damage!
Feb 13, 2011 | Microwave Ovens
I used my Polder meat thermometer in my gas grill. The fat off the meat cause flames to touch the probe. When I looked at the read-out it said 406 degrees F and then HI degrees F. Now it just reads HI...
It is possible that the therrmometer has over shot the limit set on it .It can be spoiled because the hat was in direct contact with the probe and has resulted in the failure of the unit.
Aug 27, 2010 | Microwave Ovens
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
Microwave Ovens Logo
1,024 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
