Question about Zanussi Washing Machines
Wasmachine Zanussi Electrolux F1425: Hiervan is de lager van de trommel defect,is deze te vervangen? Het is een kunstoffen trommel. Alvast bedankt.
SOURCE: Fax verzenden
Kijk eens in de instellingen via je browser. ga naa het ip adres van je printer en je kan alle instellingen gemakkelijk bekijken en wijzigen.
Posted on Feb 12, 2009
  • 10406 Answers
SOURCE: PC Battery voor een Dell 4600
When I boot I get an error message - and I think the battery is to be replaced, what and how should I do?
Thanks in advance for the answer! 1. Turn the computer off. 2. Disconnect the power-cable. 3. Remove the side-panel. 4. Look on the motherboard for a silver-coloured circular piece, about 2 cm. in diameter. 5. Read the lettering on the top of the piece. 6. VERY CAREFULLY remove the piece, by lifting from one edge. 7. Take it to a computer-store, and buy a replacement. 8. Check the lettering on the top of the new piece. 9. Insert the new piece, with the lettering on the new piece matching the lettering in #5, above. 10. Replace the side-panel. 11. Reconnect the power-cable. 12. Start your computer. 13. Immediately, press DEL to enter BIOS-setup. Set the date & time. 14. Save/Exit from BIOS-setup. 15. Reboot.
Posted on Apr 25, 2009
  • 12 Answers
SOURCE: Music on my phone
Posted on Aug 10, 2009
JulesPCaut
  • 702 Answers
SOURCE: microsoft office outlook werkt niet meer
Try creating a new profile through the Control Panel and set that as the default profile to be used in Outlook.
Posted on Dec 22, 2009
  • 1509 Answers
SOURCE: 1997 Grand Jeep Cherokee Limited
Turn the key on three times with out hitting the starter and leave it on the last time the dash display will tel you the codes and you canget an idea of what's wrong. sorry I only read and write English ( american) so I can only guess this is that you want. Good luck!
Posted on Sep 16, 2010
2005 Honda CBR 1000 RR Fireblade batterij laadt niet op
Hallo, Anoniem, voordat u een elektrische component in het laadsysteem test, is het "IMPERATIEF" dat u een volledig opgeladen batterij van 12,5 volt of meer heeft en in voorkomend geval een correcte "LOAD" test kan doorgeven 12,5 volt of meer, maar weinig of geen stroom, de batterij is defect en moet worden vervangen. AGM-type batterijen vallen meer in dit scenario dan loodzuur batterijen.
1. Batterij test:
De batterij moet volledig geladen en geladen worden om de juiste aflezingen te garanderen, de aansluitingen moeten schoon en strak zijn. Als u niet werkt met een volledig opgeladen en functionele batterij, zijn alle andere spanningsonderzoeken onjuist. Permanente batterij Spanning moet 12,5-13,2 DCV zijn.
2. Spanningsspanningstest:
Start motorfiets, meet DC volt over de batterij aansluitingen, u zou ongeveer 13,2-15 DC Volts moeten lezen.
3. Aansluitingen en draden:
Controleer de statorstekker van de regelaar en controleer de batterijklemmen voor aansluitcorrosie. Als alles in orde lijkt, ga verder naar nummer 4 hieronder om te bepalen of er een mislukt onderdeel is.
4. Statorcontroles / Rotor Check: Elk van de volgende tests isoleren de Stator & Rotor. Als de AC-uitgang en de weerstandstest mislukken en de statortest overlijdt, dan is de rotor een fout (trek de primaire deksels en inspecteer de rotor voor beschadiging).
5. AC uitgangscontrole:
Haal de stekker uit de stator start motor en trek de Voltmeter naar AC volt. Smeer beide statorkabels met uw meterleiding. De motorfiets moet ongeveer 18-20 ACV per 1.000 rpm uitzetten. Lezen verschillen afhankelijk van het systeem, raadpleeg de handleiding van de service
Generische Specificaties:
22 amp?re systeem produceert ongeveer 19-26 VAC per 1.000 rpm
32 Amp systeem produceert ongeveer 16-20 VAC per 1.000 rpm
45 amp systeem produceert ongeveer 19-26 VAC per 1.000 rpm
Stator Resistance Check:
Schakel je multimeter in op Ohm x 1-schaal. Smeer elke statordraad met meterleidingen en controleer de weerstand op de meter.
Weerstand moet in het gebied van 0,1-0,5 Ohm liggen. Lezen zullen vari?ren afhankelijk van het systeem, raadpleeg de service handleiding voor specificaties.
22 amp systeem produceert ongeveer 0,2 tot 0,4 ohm
32 amp systeem produceert ongeveer 0,1 tot 0,2 ohm
45 amp systeem produceert ongeveer 0,1 tot 0,2 ohm
Stator Ground Check:
Probe elke stator draad met uw positieve leiding op de multimeter en de negatieve naar de grond.
Er moet geen continu?teit op de grond zijn op een draad.
Als er continuiteit is, wordt uw stator op de grond gekort en moet worden vervangen.
5. Regelaarstest:
Elk van de volgende tests isoleert alleen de regelaar, dus als een van deze tests mislukt, is de regelaar fout.
Identificerende draden:
Batterijlading Leidraad gaat van de regelaar naar de batterij positief.
AC-uitgangslijnen - Kabels die van de Stator naar de regelaar komen.
Ground-Wire van regelaar naar grond of regelaar kan worden geaard via de fysieke bout aan het chassis.
Regelaar Grondtoets: Zorg ervoor dat de regelaar van de regelaar is geaard of de aarddraad stevig vastzit op een goede grond (dit moet u controleren door de continu?teit van de regelaar naar de ondergrond te controleren).
Fwd / Reverse Bias Test / Diode Test:
Deze controle test de Diode-functie om ervoor te zorgen dat de AC-stroom voor de stator in DC Current wordt geregeld.
Schakel multimeter naar Diode Scale.
Plaats uw multimeter positieve lood op elke AC-uitgangsdraad.
Plaats uw multimeter negatieve leiding op de batterij Laaddraad.
De meter moet de spanning meestal ongeveer 0,5 volt lezen.
Vervolgens schakel je multimeterkabels om de negatieve leiding op de wisselstroomdraden en de positieve leiding op de batterij-laaddraad. De lezing moet oneindig zijn. Met uw meter in dezelfde omgeving, plaats uw multimeter positieve leiding op de regelaar of de regelaar direct en plaats dan uw meter negatieve leiding op de AC uitgangslijnen.
Vervolgens schakel je multimeter-leidingen de negatieve leiding op de regelaar en de positieve leiding op de AC-uitgangskabels. De lezing moet oneindig zijn.
Opmerking: Hieronder staat een tabel om de aflezingen te tonen:
Positief Leid Negatief Lead Reading
AC-uitgang 1 Batterij-laad-spanning
AC-uitgang 2 Batterijlading Leadspanning
Batterij lading leiden AC uitgang 1 ?
Batterijlading leiden AC uitgang 2 ?
Aardstroomuitgang 1 Spanning
Aardstroomuitgang 2 Spanning
AC uitgang 1 Grond ?
AC uitgang 2 Grond ?
Voor meer informatie over uw probleem en waardevolle "GRATIS" downloads die u nodig hebt, klikt u op de onderstaande blauwe links. Veel geluk en een geweldige dag.
How to diagnose no spark situation on motorcycle
CBR1000rr not charging battery weak stator bad
2004 2005 CBR1000RR Fireblade Repair Manual Download Manuals Technical $10
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR1000RR Fireblade Owner Manual
Dec 10, 2013 | 2005 Honda CBR 1000 RR Fireblade
Na het verwisselen van de batterijen van een rookmelder van de Rokonet Wisdom, blijft het sabotage alarm van kracht. Bij het afmelden wordt er een random code gegeven, waarna opnieuw een code moet worden...
Ik ben niet bekend met dat specifieke alarmsysteem maar ze werken allemaal redelijk vergelijkbaar. Na de invoering van de nieuwe batterij als de problemen brandt proberen te nemen van de rookmelder, verwijder het beslag, activeert de rookmelder door op de knop of het zetten van een magneet op het opnieuw installeren van de batterij (dit zal de rook te wissen) en zorg ervoor dat de rookmelder correct is gemonteerd op de basis. Als het indrukken van de code en uit of uit een paar keer niet werkt, zorg ervoor dat uw systeem is op test met de bewaking bedrijf en eigenlijk op weg van de rookmelder door op de testknop of zetten een magneet tot het. Nadat het alarm is afgegaan ontwapenen met uw code en kijk of het probleem is verdwenen. Als geen tijd om de rookmelder te vervangen. *** Ik gebruikte Google Translate om deze vraag ik hoop dat u begrijpt beantwoorden ***
Aug 10, 2013 | Rokonet Home Security
Ik ben in het bezit van een GARDENA C1060 profi. Ik heb er geen garantie meer op en heb deze opengeschroefd. Het huis heeft een scheur, waardoor deze gaat lekken. Het water spuit eruit. Is er geen...
Ik spreek geen Nederlands
http://translate.google.com/#
Bevriezing ijs bevat Gardena timer Breake plastic onderdelen.
Gebroken plastic is veel voorkomend probleem. Verschillende mensen vragen over dit probleem.
Ik denk niet dat lijm zal het werk.
De waterdruk zal breken de lijmverbinding.
Gardena bedrijf zou verkopen onderdelen. Maar ik heb net gezien dat een internet bedrijf verkopen Gardena onderdelen.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
http://www.gardena.com/
May 07, 2011 | GARDENA Water Timer
Ik moet het lampje van mijn heteluchtoven vernieuwen maar, waar zit dat???
Goede dag,
De lampje voor uw magnetron is gelegen onder de binnenkant van de omslag.
U zult het deksel op de lampje te vervangen los te draaien.
Dit is meestal een eenvoudig proces en vereist slechts een sterpunt schroevendraaier.
De beste wensen,
Graemevm
Mar 24, 2011 | Microwave Ovens
Heb foutcode 800488fe,kom niet meer in mijn account hoe los ik dit op?
Vermoedelijke Reden
U ontvangt deze fout Omdat De anomalie?n in uw Windows werden gevonden Leef rekening.
Achterhaal het probleem
Vergewis u eerst ervan Dat niemand anders uw rekening gebruikt, Wanneer u te vele e-mails Binnen 24 uren stuurt of zijn vele commentaar op Verschillende blogs of profielen op Windows Leven, in de meeste Gevallen, Microsoft kan interpreteren dit verlaten zoals spam mei Activiteiten en bijgevolg uw rekening Tijdelijk belemmer.
Te bevestigen dat uw rekening hier gaat en volgt de op het witte doek Instructies om het controleproces te vervolledigen. In Sommige gevallen Kan het Worden Gevraagd een mobiel nummer binnengaan, indien niet u deze procedure kunt gebruiken te bevestigen dat de rekening of u niet kunt doen zo door het Contacteren van het Windows steun door het gaan hier Leef, een moderator zal aan uw beschikking zijn en die u zult helpen eigenaarschap van het Windows Terug te winnen Leef.
https://login.live.com/login.srf?wa=wsignin1.0&rpsnv=11&ct=1298742766&rver=6.1.6206.0&wp=SAPI&wreply=https:%2F%2Faccount.live.com%2F&lc=1033&id=38936
Indien ik van verdere hulp zou kunnen zijn, verhuur mij weet. Indien dit helpt of lost de kwestie op, schat alstublieft het en geeft een testimonium voor mijn reactie Bedankt, Joe
Feb 26, 2011 | Computers & Internet
Betreffende receiver TX-DS838, heb melding in uitleesvenster PROTECT
Dit betekent dat de versterker een fout heeft opgemerkt.
een aantal oorzaken zijn als volgt:
- een te hoge temperatuur, dit zou na een half uur afkoelen zijn verholpen.
- interne software fout, deze zou na 5 min zonder spanning verholpen zijn.
- een kortsluiting in (een van) de luidsprekers, alle luidsprekers loskoppelen kan zekerheid bieden.
- een defecte stuur of eind trap.
helaas is in de praktijk het laatste de meest voorkomende oorzaak en dient de versterker te worden gerepareerd.
Dec 26, 2010 | Onkyo TX-DS838 Receiver
Waste ink near full
I'm having the same problem. Lots of solution for resetting the printer, but none of them helping me to lead me to the absorber itself inside the printer. It seems to be a lot of work and disassembling half of the printer! Looking on internet I haven't found any answer yet.
As I am living in The Nehterlands I'm looking for solutions in Dutch. One solutions discribes disassembling another Canon printer. This could possibly help. I'll paste the text below. It's dutch, so you'll have to translate it.
Wishing you succes with this matter!
Dutch text:
Wat te doen bij de melding 'Afvalinkt bijna vol'?
Onderstaand verhaal geldt voor de Canon SmartBase MPC200; voor andere Canon
printers geldt ongeveer hetzelfde, met uitzondering van de reset-procedure (zie
hieronder).
Oorzaak
Onderin de printer bevindt zich een langwerpig, dik vloeiblad (een soort spons van
vilt). De overtollige inkt, bijv. de inkt die gebruikt wordt bij het reinigen van de
koppen, wordt afgevoerd naar deze spons. Als deze spons bijna verzadigd is,
verschijnt bovenstaande melding. Dat is ook nodig, want als je gewoon door zou
kunnen gaan, zou de spons geen inkt meer opnemen, en op een bepaald moment zou
je merken, dat de printer zou gaan 'lekken'. Geloof me, dat wil je niet meemaken.
Printerinkt is gemeen spul!
Canon
Het lastige is alleen, dat Canon nogal moeilijk doet over deze melding. Zij hebben
maar één oplossing: opsturen en het probleem door hen laten verhelpen. Kosten: ruim
€ 100,-!!! Toen ik dat van de telefonische helpdesk hoorde, reageerde ik met: "Dan
kan ik beter een nieuwe printer kopen!" De telefoniste was dat eigenlijk wel met mee
eens.
Zoeken
Vervolgens ben ik gaan zoeken op het internet. Wat je daar niet kunt vinden, bestaat
niet, tenslotte... Toen merkte ik al snel dat ik niet de enige was met dit probleem.
Iedere eigenaar van een Canon-printer krijgt er na verloop van tijd mee te maken.
Helaas was er geen kant-en-klare oplossing voor mijn printer, maar door de
beschrijving bij andere printers kreeg ik wel een idee over de oorzaak van het
probleem en wat ik eraan zou kunnen doen.
Oplossing
Over de oorzaak heb ik al geschreven. Over de oplossing gaat het nu. Die gaat in twee
stappen:
1. De vilten spons schoonmaken.
2. De printer resetten.
Dit is een vies werkje. Doe een schort om en gebruik huishoudhandschoenen! Inkt in
je kleren gaat er niet meer uit en op je handen duurt het een hele tijd!
De spons ligt helemaal op de bodemplaat onderin de printer. Je moet dus een beetje
handigheid hebben en niet bang zijn om een schroevendraaier te gebruiken.
Schroef eerst de beide zijkanten van de printer los. Die zitten elk met twee schroeven
vast (één aan de voorkant en één aan de achterkant).
Verwijder dan het toppaneel (met de scanplaat). Die zit vast met twee schroeven aan
de achterkant en drie aan de voorkant (deze drie zitten aan de onderkant van het
bedieningspaneel). Let op: zodra je het toppaneel verwijdert, merk je dat die op drie
plekken vastzit. Op één plek met een schroef (gewoon losdraaien) en op twee plekken
aan de elektronica. Trek die twee punten voorzichtig los. Je kunt het toppaneel nu
opzij leggen.
Dan moet je de printplaat verwijderen. Maak eerst alle 'draden' voorzichtig los. Kijk
goed hoe het vast zat, om het later weer te kunnen bevestigen. Maak dan de printplaat
los (4 schroeven). Verwijder daarna ook de metalen plaat, waarop de printplaat vast
zat.
Je bent er nu bijna. Het bovenste deel van de kast (voor zover die er nu nog staat) is
op de vier hoeken met schroeven bevestigd op het onderste deel van de kast. Je moet
misschien wel even zoeken, want ze zitten diep weggezakt. Schroef ze los.
De bovenkant en de onderkant zijn nu los van elkaar, maar nog wel met draden en
elektronica aan elkaar verbonden. Maak die verbinding niet los, dat is niet nodig.
Doe nu het schort om en de handschoenen aan!!
Je kunt nu bij de bodem van de kast komen. Daar zie je de spons, die zwart is van de
afvalinkt. Kijk eerst hoe de spons erin zit, voordat je die eruit haalt.
Maak de spons voorzichtig schoon. Niet wringen en zo, alleen uitspoelen en eventueel
induwen om de inkt en het water eruit te halen. Ga een flinke poos door, totdat er
alleen nog schoon water uit de spons komt.
Hang de spons een paar uur te drogen in de zon. Gebruik daarna een föhn om ook het
laatste beetje vocht eruit te halen, zodat de spons weer kurkdroog op zijn plek gelegd
kan worden.
Zet de zaak nu weer in elkaar. (Als je het net zo doet als ik, houd je twee schroefjes
over, maar mijn printer doet het nog steeds prima. )
1a. Niet schoonmaken maar bestellen...
Sinds kort weet ik dat je de spons ook kunt bestellen. Dat scheelt een boel pruts- en
schoonmaakwerk.
Je kunt de vilten spons, die uit 2 onderdelen bestaat, bestellen bij ETB (Electronic
Trading Benelux).
Bel naar 0165-850500 en bestel de volgende artikelen:
HC1-0795-000
QA4-0213-000
Toen ik ze bestelde (in maart 2006) waren de kosten voor deze 2 onderdelen samen
maar E 1,04!!
Deze prijs was wel exclusief btw en verzendkosten. Maar omdat ik het samen met
andere producten bestelde, had ik daar geen last van.
Als je nu de printer weer aanzet, kun je merken hoe dom het apparaat is. Hij heeft niet
in de gaten dat de spons weer schoon en leeg is. Dat moet hem nog verteld worden.
Op het internet kon ik daar geen geschikte procedure voor vinden, dus ben ik maar zo
brutaal geweest om Canon op te bellen. Eerst deden ze afwerend (ik moest de printer
opsturen), maar toen ik vertelde, dat ik het grootste deel van het werk zelf al gedaan
had, kreeg ik een technicus aan de lijn, die me stapsgewijs uitlegde wat ik moest doen.
De stappen laat ik hieronder volgen:
1. Zet de printer aan
2. Druk op de (langwerpige) menuknop
3. Druk op de meest linkse ronde knop (Copy)
4. Druk op de ronde knop rechts daarvan (Scan)
5. Druk twee keer op de meest linkse ronde knop (Copy)
6. Druk op het min-symbool (links van OK); het scherm zegt nu: 'Test mode'
7. Druk op OK
8. Blader met het plus-symbool (rechts van OK) tot het scherm zegt: '#8 Printer
Test'.
9. Druk op OK
10. In het scherm staat nu: '8: Printer Test' en daaronder: '- 8 - 2 +'
11. Druk 1x op het plus-symbool; in het scherm staat dan: '- 8 - 3 +'
12. Druk op OK
13. In het scherm staat nu: '[0]: Ink Count'
14. Druk op OK
15. Druk op de knipperende oranje knop om die uit te laten gaan.
16. Mogelijk werkt dat niet. Trek dan de stekker uit het stopcontact.
17. Wacht even. Doe de printer weer aan.
18. Als het goed is, ben je nu bevrijd van de irritante melding over afvalinkt.
Succes!!
Nov 04, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Wat te doen bij herhaalde bsod's met deze tekst: C
Hello excuseer me voor slechte vertaling aangezien ik Engels ben, vertelt dit u dat de aandrijving van C slechte vlekken heeft gegevens bederven is in deze slechte vlekken en het maken van u chkdsk continualy dit kan zijn harde aandrijving C te vervangen, hopen heb ik deze correcte vertaling
Apr 13, 2010 | Compaq Presario Notebook
Hoe oud is deze wasmachine(lavamat 88840-w type nr 15190302) verwarmings element en thermostaat zijn goed maar toch wast ie koud!!! dus hoogwaarschijnlijk electronica stuk??? moeite nog waard om hem te...
Ik heb een lavamat 88840-w wasmachine en het deurslotje is net gebroken. Er zit nog een stukje in het deel van de wasmachine, Wie weet waar ik onderdelen kan kopen voor deze machine en hoe ik bij het slot gedeelte in de machine kan komen.
Feb 23, 2010 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
183 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
