Hello, this has just happened to us! What are our options to fix this TV.
    Brigadier General:
  • 8,909 Answers
And what happened to you? It does not explain.
Posted on Jan 01, 2011
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
Demo mode options on bottom of the TV
Try removing power from the set for a while to see if that will now help or not.
Nov 05, 2012 | Hitachi Gst Hitachi L40A105 40" Class LCD...
Have a vizio tv and an input locked messages appeared and turned the tv off . Now when you turn the tv on the tv shuts off. How can we fix this? We unplugged the tv and pressed the side . We plugged the...
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the side of the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV
6- Power the TV back on
Apr 27, 2011 | Vizio M370VT 37 in. LCD TV
Hello.I have a great 52' LCD Sanyo tv. It is damaged. The screen is not crack or broken but when I turn on the tv it looks like a broken window and there are rainbow lines verticle down the screen....
The underlying LCD panel has broken. this can happen on many devices and is often a result of a drastic temperature change. the only option is to replace the screen ether yourself or have it done at a local tv repaire center. if the product is still under warranty it should be replaced by the provider
Mar 05, 2011 | Sanyo DP42746 42 in. Plasma Television
Tv shut off and the timer light is blinking. we unplugged tv but its still happening. please advise
hello,usually the cause in jvc tv is, a bad contacts on the vertical chip leges. you should solder those contacts. another option is to change the vertical chip . more rare is a missing of the 27v voltage that goes to the chip. in that case you should check the port of the high voltage transformer.
good luck!
Jan 29, 2011 | JVC AV-27D302 27" TV
No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Feb 07, 2009 | Vizio L32 32 in. LCD HDTV
Sony Trinitron KV - 36FS13 36" flatscreen
Hello MLD110368
I think, TV screen has white-balance failure thats why TV light blinks 5 times.
While living in Pakistan, I can't fix your TV there. In my point of view, it doesn't cost much and you should contact nearest Sony repair shop.
Apr 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
42PD6600 A
i have the same problem did you ever get this fixed??
Mar 19, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
