Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Dyson blowing top of cyclone air release valve.
Hovering normally for 30 seconds in up right position then loss off suction then loss of air through valve at top of filter above cyclone.
  • Anonymous Apr 11, 2009
    I had the same problem. I removed the bottom elbow piece (it's the piece that is connected to the hose at the base -looking at it from the back) and sure enough it was clogged! it had a mini marker in it, plastic piece, and a dryer sheet. Once I cleaned it out it the suction was back to full force! Thanks!
It sounds like the same problem I was having. I had loss of suction through he hose then all of the air was coming out through the vent/valve on top of canister. If you are looking at your dyson from the back, look at the bottom. You will see a purple plastic tab on the bottom left. That allows you to remove the plastic u-shaped hose that goes from the hose to the bottom of the dyson. I just removed that and found it was completley blocked. I removed it and the dyson has no loss of suction orair through top valve/vent. I hope this helps. I never post but i'm just excited that I got my dyson working perfectly again.
Posted on Jul 11, 2008
  • jsgreenwald Jul 11, 2008
    Sorry for the double post. I couldnt find the edit button. I meant to say, I removed the blockage and reattached the plastic hose. I no longer have any loss of suction or air.
Hello! I had the exact problem. The dyson would start up and then about 10 sec into it, it would **** air into the top valve there in front of the attachments. I released the bottom elbow piece (the one you see when looking at the back of the vacuum, at the bottom; color is purple on this DC14). It was clogged SHUT with foam, feathers, tons of hair, dust, and even a writing pen! lol Unclogged; works like new. Thank you!!
Posted on Mar 30, 2009
I tried all the above and did inevitably find some lumps of dirt. However, I also had to unscrew the bottom part of the hoover (to expose the spinning brush). I used a penny to unscrew three of the holding silver nuts to find a lot more heaps of fluff. Dont be afraid to tug and pull at some of the plastic components to persuade them to come out! It all goes back together again quite easily.
Posted on Nov 01, 2014
I had the same problem. Called the engineer. They checked over the phone that I had washed the filters, which I had. However when the engineer came he said the filters weren't clean enough. On the DC14 you should give the sponge a good rinse and squeeze but also you should gently scrub and soak the filter holder. Not just run it under the tap as per the diagram. This fixed the problem.
Posted on Mar 06, 2013
  • keoghly Jun 06, 2013
    I had to use a pretty strong jet of water from the garden hose to clean out the filter holder. if you hold it up to the light (without the blue filter......) you should be able to see the light through it. It took about 15 minutes of determined cleaning to get to that state. The result was the the machine now behaves like new.
Loss in suction?
I think, it's a "safety" vacuum release valve to cool the motor when the suction from the vacuum head is blocked.
Please clear blockage in the suction head.
Dec 24, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson d14 animal keeps cutting in and out. When it's on, the hole above where the filter is, keeps making a loud suction noise and it won't clean up hair and dirt.
Vacuum Cleaners require AIr-Flow. Your machine is not getting any air-flow. The noise you hear is a valve opening up to prevent your machine from overheating and burning out the motor.
You probably have an obstruction somewhere in the machine. Dysons are kind of known for that in the vacuum cleaner world.
Check all air channels and clean them out. If that fixes the problem you still might have issues that caused it to clog up.
I posted the part second because it takes 24 hours to complete it.
Be sure you wash your Washable Pre-filter. It needs to dry for 24 hours. Never put it back in the machine wet.
Once it is completely dry reinstall the pre-filter and your machine should be back to normal operating functions.
Let me know f this helps.
Dec 31, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hi loss of suction on Dyson DC07 and I have changed the belt on the brushbar and cleaned all filters/removeable parts but still suction not very good, any other suggestions?
Check for a clog where the power nozzle connects to the hose. Clogs or leaks in the hose will both cause loss of suction/air flow. Another possibility is broken or worn out fan blades.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson dc08 has a loss of suction. A flap valve operates within a few seconds of startup which appears to divert air. I have replaced both the hepa and sponge filters but the problem persists. If there...
You have used your Dyson too long without thorough cleaning - Here's how.
Obtain a torx screwdriver, or a set of torx bits, you will need to select the correct size when you come to remove the screws. They are all the same, so you will need only one.
Take the radix catridge off the machine as if to empty the clear plastic sucking container. (From here on your hands get dirty).
Firmly pull out the inner conical funnel. Here it is removed. (Note I am showing photos of the cleaned device).
Next remove the three torx screws. You can see the recesses these are hiding in in the above picture they are the holes without nozzles. The screws are self tappers screwed into plastic, and are easy to undo.
Remove the lower part of the housing and its rubber sealing ring.
Note the orientation for when you put it back together. The above photo shows the lower bell housing opened away from the top part as if opening a door. It's pretty hard to put them together incorrectly so don't worry too much.
You now need to remove two further screws which are recessed into the sides of the inside of the housing. Their positions are easy to find as they are the only recesses large enough, and match up with two curves on the outside of the housing. They are at the left and right in this picture.
Next you need to remove the handle at the top of the radix housing that you normally use to pick up the device.
Remove the two screws deep in the tubular holes you can see at the right of this picture.
Then slightly lift the end of the handle at the end where you removed the screws.
Next use a screw driver to push the other end of the handle off the housing away from the end where you just removed the screws.
This picture shows the handle pushed out (or ready to be re-attached)
Finally remove the screw revealed by removal of the handle.
You can now lift off the top housing revealing the wormy looking cyclone device This is where most of the **** builds up.. Lift this off and clean everything out thoroughly with water.
Make sure everything is clean and dry!!!!
Re-assemble in reverse order.
Now your Dysin is restored to original sucking power.
May 19, 2010 | Dyson DC08 Cylinder Bagless Canister...
Loss of suction
DYSON DC08 ROOTCYCLONE Loss of suction problem.
I had this exact problem and solved it.
No offense to Dyson Customer Service, but that advice isn't nearly enough to explain how to clean the cyclone. I used to work in Customer Service for an electronics company and I never let anyone down because of clear and precise instructions.
So, here is my advice:
NOTE:
Remember properly where all the screws go and how the bits fit together. It's important so that there is no loss of suction due to improper replacement of parts.
Step 1
Remove the canister from the vacuum cleaner and take off the clear bottom bit - the container for dirt. Clean that out well, you can use water but MAKE SURE IT DRIES COMPLETELY.
Step 2
Pop off the conical bit at the bottom of the cyclone. It isn't held by any screws, just nudge it out of place.
Step 3
You will see three holes amongst the vacuum entry holes. These three holes have screws in them. Unscrew those.
The type of screws used are star-like, but I used a small flat-head screwdriver. Make sure the edges of the flat-head fit perfectly into the edges of the slot on the screw. This prevents grinding and damaging the screw.
Step 4
Turn the canister over, the grey handle conceals three screws. Two on top and one beneath the bottom of the handle at it's base. When you remove the two screws that are visible, you can gently pop off the handle from the canister. First pull the handle up slightly, then the hook unlocks at the base, then push the handle away from the air inlet hole.
Step 5
Turn the canister over again. The bit where you removed three screws should come off easily. Beneath that, you will see two more screws, holding the top bits together. Remove those screws.
Then, all of the cyclone is loose and you can clean each bit separately. Again, you can use water, but let it dry very well.
Step 6
Put it all back together.
Apr 13, 2010 | Dyson DC08 Cylinder Bagless Canister...
Cyclone action is not working
When the Cyclone Assembly on the Dyson is not spinning around, it usually means that you are loosing suction somewhere. This can either be caused by a clog, suction leak, or dirty filters. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem # 1. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the vacuuming position with the handle down. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the handle was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem # 4. The Dyson DC07 has two filters on the vacuum. The first filer is the pre-motor filter. This filter is located on the right side (if you're standing in front of the vacuum) underneath of the of the cyclone assembly. There is a filter catch that holds the filter and the filter bracket in place. Simply press the filter latch, and remove the plastic circular part that comes off. In side of this plastic part you'll find the pre-motor filter. This filter is washable, but if it hasn't been washed recently, this could be the source of your suction loss. Here's what a clean pre-motor filter looks like, compared to a dirty filter:
The second filter in your Dyson is the HEPA filter. The HEPA filter is also known as the post-motor filter, or it's located after the motor. This filter typically doesn't have any effect on the suction, but you should periodically open it up and take a look at it. Despite the bogus claim of a Lifetime HEPA Filter. As you can see in the picture below, this filter gets filthy. When this filter is this dirty, it prevents the air flowing through the filter, which causes the air to look for other ways to escape, causing the dirty air to escape unfiltered. A dirty filter can also take away from the life of the motor. Here's how you can access the HEPA filter.
First remove the dust bin completely from the vacuum cleaner. Take a flat head screw driver, and right where the dust bin was sitting you'll see a groove. Put the flat head screw driver, and pry this groove off. Here's a picture of that: de80f32.jpg
Also on both the left and the right side, there are two more grooves that need to loosened before the filter can be removed:
After loosening three grooves, one on the front, left and right sides, the HEPA Filter cover can be removed. Inspect the filter to see if it's dirty. Here's a look at what a dirty filter looks like compared to a brand new filter:
I'm pretty sure that one of these solutions will help you with your loss of suction, and the cyclone assembly not spinning.
If one these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page, and let me know specifically what happened after trying these solutions. We can then narrow down the possible problems, and help you get your vacuum fixed.
I really hope that this repair was helpful to you. If this repair did help you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Apr 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction loss?
hi samdan... have you checked all the hose attachment vents .. ie Under the vacuum as well... How long is it since you replaced the filters?
Try giving the Yellow cone inside a blow out. these tend to become clogged from time to time!
Regards Faggly
Mar 21, 2008 | Dyson DCO3 Absolute Bagless Upright...
Dyson DC07 loss of suction
Hi.
Check brush roller is spinning when vacuuming.
Check short clear hose under machine for rips & blockages.
Chris..
Jan 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
3,827 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
