Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag gemini double oven range. I spilled water and unit began smoking and burnt ignitor switch. How do I get to it to replace it. Cook top does not lift up.
  • 161 Answers
SOURCE: Maytag Gemini electric oven
Well my friend these type ovens have eyes and sensers. It could be that you left something on the sensor when you were cleaning it. That is if it is not self cleaning. Self cleaning gets real hot and could affect your appliance in some way. It shouldn't but it might.
Posted on Aug 07, 2007
buffalonyman
  • 1865 Answers
SOURCE: I have a Maytag Gemini double oven with a gas
18" is standard
Posted on Apr 16, 2009
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
milten1
  • 1304 Answers
SOURCE: I want to remove the cook top off my Maytag Gemini
there are two very small screws on the corners above the door, some times more along the whole front
once removed your top will flip right up
Posted on Oct 03, 2009
mgprice
  • 744 Answers
SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
Posted on Nov 02, 2009
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
I have a maytag gemini double gas oven and the bottom will not heat up. modle # MGR6775ADW. what might cause this?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 26, 2011 | Maytag MGR6775A Gas Kitchen Range
My top oven will only broil
heatman101
Nov 26, 2010 | Maytag Gemini 30" Self-Cleaning...
My Maytag Gemini Gas Range works fine as far as the four burners, the bake on the top and bottom oven, but the broiler on the top oven does not work. Is this a pilot issue? I really appreciate the help,...
If the broiler burner is not coming on it may be a bad ignitor or the ignitor may not be getting power. Observe the ignitor when you turn in on ans see if it glows at all. If not then test for power to the ignitor if you have power and not glowing or lighting replace the ignitor. If it glows but does not light the ignitor may just be weak replace it.
Nov 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Has anyone else had a serious problem with the electrical wiring in their Maytag Gemini Gas Range? Without using the stove, the ignitors started firing and then stopped when I turned all the burners on....
Same problem here - and I have read about others with this problem. Usually blamed on moisture getting into the control unit ( which is under the backmost burner knob). I did not have a spill on the cooktop, nor was I "over zealous" cleaning. Looks like a bad design. Waiting to hear from the technician how much THIS is going to cost me...
Jan 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Bottom oven will not heat up.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jun 11, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Aug 06, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
42 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
