Question about LG Refrigerators
Freezer is working but Fridge is at 26 deg, large blue bulb not working and smaller black bulb not showing anything?
  • 29 Answers
Check the fan located on the lower back of the refrigerator to make sure it is free of lint and dust
Posted on Jan 02, 2011
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
Bosch KGU 34640 freezer not cold enough
I had a similar problem a couple years back with my freezer. Behind the vent cover in the back there were a few lines that ran the cooling or something like that. What happened was my freezer was icing up horribly. I was told to take that panel off and check those lines. Sure enough one of the lines was busted through. That was why my freezer was having problems. I apoligize I don't know anything about the front buttons tho.
Dec 28, 2013 | Bosch Refrigerators
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
Srl629ev refrigerator
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge.Otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | Refrigerators
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
Jan 01, 2011 | KitchenAid Architect Series II KSRG25FVMS...
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Looking to buy a maytag side by side fridge freezer in black/chrome what is the sm allest depth they do that will fit in with my kitchen units
Maytag and most other manufacturer's, are making what's called "counter depth" fridges. These fridges typically only extend out from the wall only as far as a traditional countertop (24" to 26" +/-).
However, most of these fridges have a smaller Cubic Foot capacity inside them, so large familes would be advised to stick with traditional fridges, which have the largest capacities available.
With that being said, here's a link to Maytag's site that will let you pick out the style of fridge you want and select the counter depth model you prefer.
http://www.maytag.com/catalog/kitchen_products.jsp
I hope you find the fridge that you want and that this little bit of information has been Very Helpful for you. Best regards!
Oct 01, 2009 | Refrigerators
Blue fluid leak
There is no blue fluid in a refrigerator.
Something external or a add on is causing the blue fluid.
Mar 13, 2009 | Kenmore Refrigerators
Refrigerators Logo
43 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
