Question about Amana AMC5101AAS Stainless Steel 1000 Watts Microwave Oven
I have owned a AMC5101AAW for about three and a half years. It has been a good microwave,perfect for my needs. The display went black and the buttons didn't work right after I boiled a cup of water for tea this morning. An hour later the display window showed a 8888 indicating the power was on. I set the clock and put a cup of water in the oven. As soon as I pressed the start key the power went off again. Also when I shut or open the door the power may or may not go on but although the clock and input buttons appear to work each time the display lights up everything stops when I push the start button. I tried this a few times. Also I don't know if this could have contributed to the problem but the oven overheated while I cooked a casserole a few months ago. I don't remember the timing exactly but it needed more than 12 minutes of cooking time. It stopped working just like today but started working a few hours later and has been ok until today. My question: Is this worth fixing? I'm thinking I might be a power supply or maybe a card has burnt out. I don't know what it cost to have a microwave fixed but if it's close to the price of a new one it is probably not worth it. Thank you in advance for your help.
    Brigadier General:
  • 8,909 Answers
It sounds like it could be just a bad crimp connector supplying power to the whole system, which would have to be the fuse holder on the mains input panel.
Worth a look!
Posted on Jan 01, 2011
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Hi there. I have had my fridge freezer for about 1 and half year,but the fridge is not working.The freezer works perfectly fine. can you help please? Thnx
I suggest that half of the system is not working and recommend the services of a refridgeration engineer as it may need re gassing.
Jan 08, 2011 | Microwave Ovens
Microwave starts on its own and displays PAN
You have a shorting membrane keypad.
I'm contacting you directly.
May 22, 2010 | KitchenAid KHMS155L Microwave Oven
MW8115SS worked perfectly and then went dead
Blown fuse , take the outer cover off and change the fuse. Iff you don't have a fuse use a piece of tin foil until you find a replacement fuse.
Hopefully this helps you out.
Aug 18, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Our microwave went dead. It's only three years old. My husband put some chicken wings in, closed the door, and everything went black. We plugged in a nightlight in the power source and it worked. Any ideas...
a few possible causes,
1, the high voltage fuse,
2, the high voltage capacitor
3, the slow blow fuse ( normally found on a small pcb inside unit)
other than that, check the door switches and maybe the x former.
good luck.
Jul 04, 2009 | Whirlpool GH4155XP Microwave Oven
Buttons not responding on nn-s235
My microwave nn- s235 have the same problem only stop botton waork but no child is displayed in the display
Jun 14, 2009 | Panasonic Microwave Ovens
Sharp R510AK Carousel Microwave
Very common problem with the display. It may or may not eventually light back up on it's own.
I would suggest contacting www.microwavedisplay.com. Lots of info and the best deal going for repairing the display.
Jul 03, 2008 | Sharp R-510HW Microwave Oven
Touch pad went dead
your Display board will need to be replaced
Jan 23, 2008 | Panasonic NN-S254BF Microwave Oven
Amana AMC5101AAS Stainless Steel 1000 Watts Microwave Oven Logo
124 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
