Question about HP Deskjet 3845 InkJet Printer
My printer is not printing anything, its turned on and connected properly. except the on button is flashing instead of staying on, and in the settings i couldnt find the right model number, so its default is hp deskjet 3840. I dont know how to fix it. It used to work, and it just stopped. Please help
  • 132 Answers
Try turning off and putting more paper in then on again.
Posted on Jan 01, 2011
When i open the printer the led flashes orange.. and i cant get print.. i checked the connection and power they are all fine..
Try resetting the printer.
How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.
Jan 25, 2011 | Intermec EasyCoder PC4 Label Printer
Installed gigabit MB new power supply, all new parts and only get flashing lights on the optical drive on boot up any ideas what i could be doing wrong ?
1. Check whether two power connectors are connected (one is 20 pin and the other 4 pin)
2. Remove all FRONT USB, Audio, HDD, CDRom and other connections on motherboard, except the power button connection now turn on.
3. If still does not, instead of Power button use reset button connection for Power button and try.
4. Check whether proper memory supporting type is installed in proper direction, try putting in another slot.
5. Change the SMPS eventhough it may be powering on.
6. Check the Motherboard by keeping it externally taking precautions.
Sep 11, 2010 | Intel Motherboard
My on button stays on will not turn off and the cancel button flashes orange
try this below....
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for trouble shooting
hope this helps and good luck
Apr 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
It is not printing anything, the standby button keeps flashing
Is it connected properly?
Does it require any specific software?
Have you checked the manual?
Apr 09, 2010 | Lexmark Z640 InkJet Printer
My samsung ML2010 printer has Error button flashing green
your printer is not inisilize properly. it is a logic card problem.so pls you can repaired it from printer vendor.
Sep 02, 2009 | Samsung ML 2010 Laser Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
Printer not working
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Won't Print But Ready Light On Fan nonstop
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Apr 04, 2008 | Brother HL-2040 Laser Printer
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
Sep 19, 2007 | HP Photosmart D5160 InkJet Printer
HP Deskjet 3845 InkJet Printer Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
