Question about Cozy (W352E) Heater
I have a Cozy dual side wall furnace. A few weeks ago it was making a loud popping sound like someone hit the heater when it was running for awhile. Now it doesn't make that noise but when the thermostat clicks on the burners don't ignite right away releasing some gas till it reaches the pilot then a flame rolls out but after that it runs normal. HVAC guy said it could be a nest in my vent but took it apart and thats not the problem. Does anyone know what I can do to fix this.
hotuna
  • 288 Answers
SOURCE: Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Posted on Dec 23, 2007
hotuna
  • 288 Answers
SOURCE: cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Posted on Dec 25, 2007
  • 10 Answers
SOURCE: cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Posted on Feb 03, 2009
shastalaker7
  • 1515 Answers
SOURCE: Cozy wall furnace burner will not light. Pilot
Hi, have done this to many times not to know. I will walk you through this. It is good that the pilot is lit. Go to the stat and remove cover. Don't worry as this is a milivolt unit, no voltage or such a small amount you wont even notice as this is why it is called milivolts.Take a small screw driver to remove the next section which is the thermostat and will expose the sub-base where you will find 2 wires connected to it. You may have 2 or 3 screws to take loose to get to this last section. Anyway, if you have a piece of insulated wire laying around, even old speaker wire will work, take it and touch the wire across the 2 terminals and hold. If the furnace comes on, the thermostat is faulty, and you will need to buy a new one. No power to shut down, and simple to change. Cost about $12.00 dollars. Try and get a heat only milivolt stat as they are much less expensive and will have less problems with them. Go to home DEPOT to get one, or O.C.S.H. will also carry them. Don't let the salesman talk you into buying a programable heat and cool stat, 24 volts as they will work, but cost more and you don't need it!! Look around even if you need to go to a wholesale Refrigeration, Air Conditioning, and Heating parts house. Tell them you need one for a unit in some apts you own, and you will pay cash as you want a cash account. They will only ask what job its for, and just tell them your name. This is not illegal and I wouldnt tell you this if it was!! You will still have to pay taxes but will get a wholesale price for it. I am sure it will fire up when you touch the 2 wires and prove stat is bad. For some reason it is not the stat, follow the 2 wires from the stat down to gas valve and jump the same 2 terminals there also. If it fires up, you will have a problem in the wires from the stat to heater and will need to be replaced. I don't think this is the case. But, on the chance it will not fire after you have done all of the steps I have had you do, then you have a faulty main gas valve(MGV) and will need to replace. This is all easy to repair.I am a 100% sure it will fire up when you jump the 2 wires together, and you will need the stat. Please let me know as I will be waiting for an update! Good Luck,
Shastalaker7
PS When you install the new stat, make sure it is Level.
Posted on Dec 18, 2009
shastalaker7
  • 1515 Answers
SOURCE: Cozy Wall Gas Furnace Pilot won't stay lit
Hi, if you have replaced the thermocouple or thermopile generator, and it keeps going out, you will need to replace the gas valve. That's all it can be is the milivolt coil on the valve, trust me. I have been through this many times.
Sincerely,
Shastalaker7
Posted on Dec 29, 2009
Testimonial: "Very helpful, hit the mark right away - had I used Shastalaker7's advice from the start I could have saved A LOT of money, time and headache!"
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
Cozy wall heater
Check flue pipe,old flue pipe may have soot,also check vent flashing may be restricted
Jun 25, 2014 | Cozy (W352E) Heater
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
How can I clean my suddenly stinky Cozy wall furnace?
It may well need a service if you have not had it done in 12 years this could well be a job for a gas fitter
Sep 13, 2012 | Rinnai Orbis Vented Heater 15,000 BTU Wall...
I have a 50,000 BTU doublesided Cozy wall furnace at my cabin. Recently the pilot keeps going out, I suspect it is caused by a chimney downdraft when I close it up for the week. Can I put a wind...
make sure you have 3 feet of vent pipe out of the roof and you have a UL listed vent cap, if you can re-light the unit all parts are good.
Nov 23, 2010 | Cozy (W352E) Heater
My cozy furnace makes a loud clicking noise every time it is running. What can I do to fix this problem?
Wall furnaces sometimes do that it is just expansion and conttraction of furnace. rus
Mar 17, 2010 | Heating & Cooling
Dec 19, 2007 | Cozy (W352E) Heater
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Nov 27, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
93 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
