Question about Poulan 18" Wild Thing Chainsaw
Is not feeding chain oil. Bar hole is open. WD 40 will go through oil hole to tank. Air pressure on tank will not get liquid out of the oil hole
dennisgladx
  • 52 Answers
SOURCE: Insufficient chain oiling
Sorry to tell you this but you need a new OIL PUMP but it's not a difficult thing to replace.
On the main shaft of the crank shaft under the centrifugal clutch is a spiral wound wire that matches a plastic part that is the oil pump. You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time.
Glad to be of assistance.
Posted on Oct 20, 2008
  • 226 Answers
SOURCE: Poulon Pro 16-inch 38cc no longer auto feeds chain oil.
Try using carb cleaner or WD40. I hope that you removed the oil cap and oil before you tried... hope this helps, rick
Posted on Apr 17, 2009
SOURCE: have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Posted on Aug 04, 2009
rwvanlue
  • 486 Answers
SOURCE: Poulan Pro 42/18 gas Chain saw: The chain oil hole
GS, there is a pump driven by the clutch sprocket/drum. Operate the engine with the bar off. There should be oil coming out.
a) If so, the hole in the bar is plugged with saw dust. This is very common on all brands of saws.
b) If not, then remove the clutch/drum assembly and inspect the worm gear drive of the pump.
*note, the threads on all chain saw clutches are Left Hand reverse threads.
Posted on Nov 13, 2009
SOURCE: bar not oiling
How do I routing the throttle cable from the carb to the handle?? I need help. Thank you
Posted on Feb 11, 2010
My Stihl MS 231 is not feeding oil to the chain how do I locate the problem and repair.
The chain and bar oil should feed from the reservoir to a small hole in the bar that feeds the oil to the bottom of the chain. If that little hole gets dirt in it, the oil won't feed to the chain. To clear the problem, remove the bar, remove the chain from the bar, and clear the hole in the bar and track for the chain in the bar. I've done this while out in the woods by just using a stiff dry piece of grass to push the dirt out. Once clear, replace the chain, teeth facing the correct way, and the replace the bar, and tighten.
Nov 13, 2016 | Stihl Garden
The chain lubricator not feeding oil
Harry, I would recommend first removing the chain and guide bar. The oil pump is not what you'd call a high pressure pump as it just kinda ooooozes oil out of the sidecase of the saw in line with openings like a slot, groove or hole in the guide bar. These slots and/or holes are notoriour for plugging up if the saw is not properly cleaned, maintained or serviced regularly. Chances are a good cleaning of these openings will solve your problem. If you have compressed air, that will work well. If not, and old tooth brush and a lot of hugging, puffing and blowing will be in order.
I have a habit of touching up the chains, and cleaning my saw(s) thoroughly after each use including cleaning the air filter, oil grooves, sprocket, guide bar and chain.
Aug 31, 2015 | Ryobi Garden
Husquavarna 455 chain oil problem
is the tin plate on the right way?(not blocking the hole)did you change the bar and the replacement blocking the oiling hole
Aug 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
McCulloch 14" chain saw Model CS 38 EM It quit
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Mar 23, 2011 | McCulloch Garden
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Nov 15, 2010 | Homelite ZR10926 16 Chain Saw
Oil leaks out of the remington electric pole saw. The saw is stored/seated upright and I can't see the problem
Remove the bar and chain, then clean the entire area. Look for leakage at either the small port where the bar fits, or from the motor case itself. Make sure the oil tank vent is open so that pressure doesn't build up from heat. If the leakage is from the case, then look for a crack in the oil tank, or a defective oil line from the tank to the oil pump. Clean the drive end of the bar oil-channels that go out from the large holes to the chain groove on each side. Clean the entire chain groove. It also may be easier to just dump the oil out of the tank after each use if the chain seems to oiling properly. Hope this helps!
Jun 15, 2010 | Remington Electric Pole Saw
Blocked chain oil feed tube on chain saw
Drain out all the oil. You will have to have a air compressor or find some one who does. With a rag to help cover the fill hole pressure the oil chamber and push the oil valve open and try to blow out the clog.
Oct 01, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Bar and chain oil is'nt dispensing onto the bar and chain
Its probably the line going to the hole by the bar, or maybe oil tank is plugged up at the outlet. If it were mine, i would take the thing apart & clean the tank, etc, but you might get something like carburator cleaner with the little straw (or WD40 should do) and stick the plastic straw down into the oil hole to try to clean it out. That might work without disassemble. Very low air pressure might also work. The oil cap should be off in any event, and the tank drained.
Doesn't have much to do with your chain being dull, usually chain not sharpened right, like incorrect angle, not having rakers cut down properly and the like. Reminds me, I have 2 saws that i need to sharpen before next week. hope this helps, Rick
Apr 11, 2009 | Garden
Location of bar oiler adjustment screw on p4018wt
THIS WORKED FOR ME....I have a 2014. I've had that problem for quite awhile. I finally decided to try to fix it. I took the bar and chain off, removed all the crud in there. Then I took a small air compressor and blew out the entire area so it was pretty clean. I started the saw at this point and gunned it some. The oil became noticible within a few seconds where it comes out at, above the outer chain bar bolt. Once I found the hole, I then drained the oil tank, and then using the air pump, blew out the hole from the blade area to the tank, leaving the oil cap OFF. Upon refilling the oil tank with a lighter oil (10 wt), I restarted the saw, and the flow was really coming. After the oil; tank empties, I'll start using the regular bar-and-chain oil again, but it's pretty heavy, even though it says it is 30 wt.
JimBo
Nov 09, 2008 | Garden
Poulan 18" Wild Thing Chainsaw Logo
90 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
