Etec model dvd 2001 Loads disc then says wrong disc
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: etec portable dvd player says
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Posted on Jul 14, 2011
Dvd loads the the disc then says no disc
Is DVD got its writing facing upwards my daughter put a dvd in our player the wrong way up and it said no disc .
Jul 11, 2014 | Televison & Video
I have a coby vzon that says wrong disc but reads cds then when cleaned and blown loads up mp2 instead of dvd or says wrong disc still please help.
All DVD players use a dual laser pick up. One laser is for CD/VCD/MP3 and the other laser is only for DVD. If you have watched more DVD and less CD's you could be having a problem with the DVD laser. Must have become week and the system cannot read the disk. Change of the lens unit will solve your problem.
Mar 10, 2011 | Coby TF-DVD7107 Portable DVD Player
Who is the manufacturer for Etec DVD model #2658? I need mine repaired before the warranty expires.
I recently discovered that eTec Electronic products are cheap Chinese imports brought into the US through a company called Schoenfeld International in Bloomington, Minnesota. They contend that there are NO Service manuals or schematics for ANY of their products because their products are so cheap, they're not worth repairing. Basically they're saying, "If it breaks, throw it away and buy another one!"
Aug 18, 2010 | RCA DRC277 DVD Player
When i insert a dvd it loads then shows wrong disc. Does this mean the laser needs to be cleaned?
hello,
when your player shows wrong disc, it is either the laser is weak or dirty.
if it is weak, it needs replacement.
if it is dirty, its just cleaning that is needed.
take care
Jun 08, 2010 | Prosonic PD-007 DVD Player
When i put a dvd in the dvd player it loads and then it says wrong disc
it has a bad laser or will not read certain video farmats. most likely the laser in my dealings with proton. bye
Nov 09, 2009 | Protron PD-007 DVD Player
When I put my disc in it loads...then it displays
Wrong disc usually indicates a problem with the lens mechanism of the DVD player. It can be dust/lint blocking the path of the laser there by preventing it from reading the disc or it can be a mechanical problem like lens out of alignment. You can attempt to clean the lens using a lens cleaner CD/DVD with liquid and see if it resolves the issue(you can get one for as low as 5$). Perform a dry cleaning first(without the liquid) and then with liquid(two drops on the brushes of the lens cleaner DVD that pop-up after the dry cleaning run. If it doesn't resolve the issue then you may have to get the lens mechanism checked by a qualified technician. You can search the fixya repair directory to find one in your area.
http://www.fixya.com/repair
Oct 12, 2009 | TruTech TT320
My DVD Pler loads but in aminute or so it says no disc
Try another disc, does this happen with all discs? the optics are most likely failing, did you try a DVD lens cleaner and also try canned air?
Mar 08, 2009 | Memorex MVD2042 DVD Player
DVD1402TVP
Buy one cdclener and insertion your DVD tray agay now
Jul 20, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
