Question about Mtd Garden
I have very recently purchased a 125/38" MTD. Not sure how old but appears in reasonable condition. I have used it for about total of 4 hours over past two weeks. Today I have a problem... the large belt driving the blades keeps disengaging as soon as I set the blade depth. I don't have a manual or much experience with ride ons so would appreciate any advice. By the way I have been careful when rewinding the blades onto the forward wheel not to place the pully over the two guide (?) pins. Also, when not engaged the pulley is very loose! Many thanks David
  • 124 Answers
My name is Dane and I am going to help you solve your problem. You said that the "Pulley" is loose when the blades are disengaged. I hope you meant that the belt is loose, because the pulley should never be loose. If it is loose, you should remove the pulley and make sure the KEY inside the center hole is still ok. Sometimes when the pulley gets loose it chews up the KEY and allows the pulley to turn on the crank. If the KEY is ok, just reinstall the pulley and tighten it.
I believe that your belt is probably just stretched and worn. The mower deck belt gets it's tension from lowering the mower deck. the lower the deck the tighter the belt. Just replace the belt. I hope I've helped! Thank you! Dane
Posted on Jan 01, 2011
Testimonial: "Hi Dane Thank you very much for taking the time to help me. You are quite correct, it is the belt that is loose and will replace. Thank you. David"
  • jdgeorge803 Mar 06, 2011
    which way does that spacer go when the crank pully is off its between pully and bottom of engine the lip side on pully or bottom of engine ?
Where can I purchase the carb cover and air filter
Google the model numbers and you should find something. I have purchased several parts through Ebay for reasonable.
Aug 31, 2014 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
I have a MTD/Lawnflite 46SPOE that is 54 weeks old. I have been advised to buy an OPTIMATE 4 to condition the battery pack on it. I need to establish the specification of the battery to make sure that...
Take both back to dealer the battery or the 46spoe and charger have them to replace what is wrong if they will not blast them on every rating site there are.
Aug 07, 2017 | Mtd Garden
Hi! I recently had work done on my fiat and now my stereo doesn't work. I am trying to input code but the stereo just shows "SAFE" not followed by the 4 dashes that are meant to appear. How...
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
This may take an hour or more
Make sure you have the correct code
Jun 25, 2011 | Car Audio & Video
I have purchased a SL82318 Handset. I have a SL82318 system, with all three original handsets working perfectly. This fourth handset displays: "Connecting..." and nothing else. According to...
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
Jan 04, 2011 | Vtech SL80108 1.9 GHz 1-Line Cordless...
To change the Date and Time on my Sharp EL-1801PIII Calculator your instructions refer to a faceplate, which I do not have. What keys are associated with "Time Set," "AM/PM,"...
GRAND TOTAL / RATE SETTING MODE SELECTOR:
"GT": Grand Total
"•": Neutral
"RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as "date" if the
value is within the following range; "Error" is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0".
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as "time" if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Dec 16, 2010 | Sharp Office Equipment & Supplies
We recently experienced a power outage and our Plasma TV did not come back on afterwards. I have read about similar problems but we do not have a red led. I have removed the back panel and have checked...
The problem with these sets is you have to gamble.
If power outage, it is most likely on the power supply board-------only way to confirm this is test voltages to see if are there or not, do you follow me?
Fuses can look good but also need to be "tested".
Let me know if I can help, I am here to help.
SD TECH
Nov 06, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
1996 Honda Passport LX starter replacement
I HERE YOU BROTHER, I TYPICALLY DO ALL MY OWN WORK BUT THIS ONES FOR THE CERTIFIED MECHANICS. I ALSO LAID UNDER MY PASSPORT FOR ABOUT AN HOUR TRYING TO FIGURE IT OUT. I FINALLY WENT AND GOT A QUOTE FROM MY MECHANIC WHO I DO USE FROM TIME TO TIME. $137.26 JUST LABOR , I HAD ALREADY PURCHASED THE STARTER. BEST MONEY I EVER SPENT! I PICKED IT UP AND HE TOLD ME (GET THAT THING OUTA HERE JOKINGLY) IT ENDED UP TAKING HIM AND HIS CREW 6.5 HOURS TO COMPLETE THE JOB. MY MECHANIC HAS ALWAYS HELD TRUE TO HIS WORD SO I WAS CHARGED EXACTLY WHAT I HAD BEEN QUOTED. THEY BROKE OFF BOLTS , TORE UP TOOLS , AND EVEN HAD TO USE A CUTTING TORCH. MY ADVICE: GET THE LOWEST QUOTE FROM A GOOD MECHANIC , MAKE SURE THEY STAND BEHIND THEIR QUOTE AND LET THEM HAVE AT IT. HOPE THIS HELPS AND SAVES YOU A BIG HEADACHE!GOOD LUCK.
Feb 11, 2010 | 1996 Honda Passport
Garden Logo
427 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
